  • July 11, 2025, 06:25:13 PM
Author Topic: Final Choices for the Veco 19  (Read 2353 times)
Online Mike Griffin
« on: December 14, 2022, 09:34:14 AM »
I have been fortunate to find a couple of Veco 19 Engines that are brand new or practically brand new so I am going to build a Pretender and a Williamson Ringmaster.  I think they will be a good fit for the engines.  My sincere thanks to those who helped make these two future builds possible by responding to my requests on these two.  I will not get started on these until after Christmas.
If anyone has built and flown these designs, I would love to hear how they flew.
Re: Final Choices for the Veco 19
« Reply #1 on: December 14, 2022, 12:36:21 PM »
Hi Mike
Sounds like a great plan.  Hoping for a build thread especially on the Williamson Ringmaster.  It'll be nice to see a Ringmaster that isn't a ringmaster - uh, you know what I mean!
« Reply #2 on: December 19, 2022, 11:28:15 AM »
 Mike I was into old time stunt for many years and I did build the Williamson Ringmaster. I did not care for the way it flew. It would not turn ever in each direction. The profile Ringmaster is a much better flyer. On paper it looks good and it fooled me into building it. Maybe the low wing is the problem. I have seen other using them for Old Time stunt and they thought the plane was OK but they were not very good flyers so there standard may have been low. It is a neat looking plane for sport flying. THE All American ,not the SR is a good flying .19 powered model and it lands much better than the SR.
Online Mike Griffin
« Reply #3 on: December 19, 2022, 01:38:27 PM »
Hi Eddy,
I knew about this problem so what I am going to do is either, raise the wing up in the fuselage by about 3/4" or....put dihedral in the wing.  I am leaning toward raising the wing.
« Reply #4 on: December 19, 2022, 05:57:25 PM »
seeing you mentioned DIHEADRAL .  %^@
And as it had a ED Racer , a Veco 19'd Do it , runnig 4-2 ish .
And if you Dont Like It , just use the Diheadral !  ;D S?P
p.s. I think it only one ' the Gold ' as most of the rest were blown into the ground , with only 3 or 4 manadgeing take off & landing . A few loops did the trick , then .  :-X
Tho plenty have been built & liked since , but ask someone who has one . Id put em in a Oriental winged twin engine Mosquito .  VD~  This'd raise your heart rate .
Offline Larry Wong
« Reply #5 on: December 19, 2022, 06:58:36 PM »
I have some Veco's 19 plane bearing and ball bearings
Larry
Offline Mike Scholtes
« Reply #6 on: December 20, 2022, 11:40:05 AM »
I have a Veco plain-bearing 19 that appears to be in good condition. I have never  run it but has good compression. Anyone who would like to have it is welcome to it! (Except Larry Wong who already has too many.) No charge. Send me a pm.
« Reply #7 on: December 21, 2022, 08:51:00 AM »
Mike,
For the  Veco 19BB search this forum, Brett Buck had some details about setups they used on Ringmaster. When setup right it is right there with the OS FP 20/25. It likes rpm, 9ish x 4 prop.
Best,  DennisT
Online Mike Griffin
« Reply #8 on: December 21, 2022, 10:14:29 AM »
Mike,
Best,  DennisT
Thank you Dennis.
« Reply #9 on: December 21, 2022, 10:31:09 AM »
Mike,
Best,  DennisT
   It's a bomb with a Veco 19bb - better have fast reflexes. It's a little less powerful than the 20FP, which is even more insane overkill. But, understanding that, yes, we (David, Ted, Jim, and myself, as an observer) have a lot of experience.
Online Mike Griffin
« Reply #10 on: December 21, 2022, 12:26:40 PM »
Thank you for your input Brett.  Merry Christmas.
Offline Airacobra
« Reply #11 on: December 21, 2022, 07:33:01 PM »
Look at the Sirroco. designed for the Veco 19  Mike
Keith Bryant
Online Mike Griffin
« Reply #12 on: December 21, 2022, 08:38:46 PM »
Keith that is an interesting looking model.  I tried searching for plans on the net but could not come up with anything that was a CL model.  Thanks for posting.
« Reply #13 on: December 22, 2022, 06:57:19 AM »
Mike,
Just for information here is the engine review article in Scepterflight website on the VECO 19BB (http://sceptreflight.com/Model%20Engine%20Tests/Veco%2019BB%20CL.html), it is interesting in that it shows the power band ~10 -12K ish which is where the 4" pitch needs to be. Also interesting on that same site is the K&B 19, it has the same power band but is plain bearing and 0.2 oz lighter. I think the VECO 19BB came out after K&B bought the VECO engine line and put the same setup as their old plain bearing 19. There is also a review of the original VECO plain bearing 19 and it is not anywhere close to the BB version.
Seems that you could start with the 9x4 and adjust pitch down to get the lap time and add diameter to hold the engine in its power band.
Best,    DennisT
« Reply #14 on: December 22, 2022, 08:11:07 AM »
Virtually all the designs of that era fly much better when they are going fast.  The magazine article for the Williamson Ringmaster recommends flying it on .012"x65' lines - probably to help the pilot keep up!  Sounds to me like the Veco 19BB is going to be spot-on!  Set the engine at a comfortable/repeatable needle (probably burbling 2/4) with a 9/4 prop then adjust the line length to suit...
Offline Airacobra
« Reply #15 on: December 22, 2022, 04:15:38 PM »
Plans for the Sirocco are on Air age
https://www.airagestore.com/plans.html
Keith Bryant
Online Mike Griffin
« Reply #16 on: December 22, 2022, 05:04:54 PM »
