  • June 25, 2025, 01:11:18 PM
Author Topic: Discovery Retro 68 tanks size?  (Read 896 times)
Offline Tim Redelman
« on: June 10, 2022, 10:31:57 AM »
What size tank are you running with your Discovery Retro 68?
All synthetic?
What brand?
Tim
Offline SteveMoon
    • www.ultrahobbyproducts.com
Re: Discovery Retro 68 tanks size?
« Reply #1 on: June 10, 2022, 01:22:52 PM »
Tim: I run the DR 68 and use a Sullivan 4 oz fuel tank.
As for fuel, I use Sig FAI fuel 10/10 synthetic/castor.
It takes about 3.625 oz of fuel to fly the full pattern and
about 6 laps after completing the pattern.
Online Massimo Rimoldi
« Reply #2 on: June 10, 2022, 01:57:59 PM »
Hi Steve.  One question, what is the diameter of your venturi ?
 Thank you, Massimo
Offline Lauri Malila
« Reply #3 on: June 10, 2022, 03:16:15 PM »
So far the best running DR.68 I’ve seen had 14-15% of Maxima #927 oil, no nitro.
No need to change the venturi (or anything) from the factory setup. L
« Reply #4 on: June 10, 2022, 03:30:19 PM »
Hi Lauri, I have two DR.68 that I have never used. They came from Yuriy, one has an 8.4mm venturi and the other is 9mm.  If I have to be honest they seem a little big to me, especially the 9 mm
Massimo
« Reply #5 on: June 10, 2022, 07:53:32 PM »
Nah .
tho it relates to plane size / drag . & weight . Might want smaller sub 60 Oz plane . ST 60 are generally  .312 BJ .  .30 to .320 tho nowadays some run .185 - .195 .
So in a biggish plane the sizes there & the atmosphereic bit , temp & barrometer , would fit . Cripes ive had a FSR 25 run good on a 7.5 m.m. ! with a 3.5 mm spraybar .
