  • July 13, 2025, 06:47:53 AM
Author Topic: Legal for Classic? Banshee, Shark 402  (Read 1513 times)
Offline Allen Eshleman
« on: June 09, 2022, 01:36:09 PM »
Is Banshee or Shark 402 legal for Classic?
Offline Phil Spillman
Re: Legal for Classic? Banshee, Shark 402
« Reply #1 on: June 09, 2022, 01:42:33 PM »
Hi Allen, The Banchee is for sure N-30 legal but the Shark is likely way too young as of yet! I remembered having ordered  a Banchee in 1976 so that's 30 plus years ago!
Phil Spillman
Phil Spillman
« Reply #2 on: June 09, 2022, 03:02:51 PM »
So how is N-30 related to Classic?
« Reply #3 on: June 09, 2022, 03:16:08 PM »
Is there a place where this is a list of kits/planes legal for the different time eras.?
« Reply #4 on: June 09, 2022, 03:53:07 PM »
The most exhaustive list I know of listing Classic and OTS models is the Dave Day's website at
http://miniatureaeronautics.com/Dave_Day/
He lists 432 airplanes for classic, 465 airplanes for "vintage".  Over the years, PAMPA officialdom has approved other designs not in the Day listings.  Some of these for OTS are the Big Job, Yates' Madman 56, and the "13".  There may be more, but I cannot recall at this time.
« Reply #5 on: June 09, 2022, 04:04:15 PM »
Thanks Keith,
That is very helpful.
Allen
Offline Shorts,David
« Reply #6 on: June 09, 2022, 05:52:01 PM »
And just in case it hasn't been explained. Classic is designed (even if not published) prior to 1970, aka December 31, 1969. Old Time Stunt is prior to 1953. N-30 is a moving date based upon 30 years prior to today's date. A couple places fly super 70s, like VSC in Arizona. But a few more contests have a profile class which includes your banshee.
Not sure if that was the answer you were looking for.
« Reply #7 on: June 09, 2022, 07:42:55 PM »
I am thinking in terms of Brodak.  I just read that Classic for them is up to 12/31/69.  So the exact question would be, when was the Banshee designed?  I know that the Shark 402 is probably not in play.
« Reply #8 on: June 09, 2022, 08:45:47 PM »
On another thread it says Mike Gretz was designing the Banshee concurrently with the super chipmunk. So, that puts it in the 70s.
Okay, as has been pointed out to me, this story is referring or must be referring to the van loo chipmunk of the 60s, not the Stott chipmunk of the 70s.
« Last Edit: June 10, 2022, 12:34:46 AM by Shorts,David »
Offline BYU
« Reply #9 on: June 09, 2022, 08:53:25 PM »
Banshee is classic legal. Mike Gretz wrote a long explanation on this forum a few years back to explain the time line.
« Reply #10 on: June 09, 2022, 09:19:19 PM »
      The The Super Chipmunk was credited to Mike Stott, and it is NOT classic legal. The SIG Van Loo Chipmunk, kit #CL-3 IS classic legal, and was originally designed by Jim Van Loo. SIG produced the kit on a limited basis at first, as Glenn did not think it would sell well, and it didn't even have a kit number for the first run because of that and was even in a shorter box that they wanted to use up. Sales went better than expected, so the kit was refined a bit, given the kit number CL-3. Top Flite had it's Nobler and the Flite Streak to compliment it as a "practice plane" at that time also. Mike Stott was working for SIG at the time and since sales of the Chipmunk were going so well,  Mike was tasked by Glenn SIG to design a practice plane that would fly similarly to the Chipmunk. He designed the Banshee along the same moments and such as the Chipmunk so it would fly similarly, and that is why it has the longish nose that it does, as it was designed around the Fox .35 which was the most popular stunt engine at that time because of it's light weight, and Fox engines did not come with a muffler at that time, either.. The Super Chipmunk came along quite a bit later and is a different airplane that the VanLoo model.  Mike Gretz had mentioned through the years that he was pretty sure that the model had been designed before the December, 1969 deadline but there was no record of it and no record that it had been put into production by then either. Mike Gretz has since passed away but has told this story here on the forum before and it can be searched up. Mike Stott is still with us I think but he has no record of it nor can recall for sure the specific time lines. With no definite documentation, not one has been flying it in Classic or Nostalgia competition. Keep in mind, that the Classic class has been around a long time now, pushing 30 years or so, and most of this has been hashed out several times before and a lot can probably be found out on the internet about it. The same thing about the Twister. Mike Gretz used to have a web page with the history of all the SIG C/L stunt designs but I do not think it exists any longer. There is a web site about the history of all SIG designs but I couldn't come up with a link right now. So , basically, to fly classic, the model must have existed, was designed, kitted or published by December 31, 1969. Tom Morris had put together two compilations of Classic legal designs and Old Tyme legal designs in book form and published by PAMPA, that you might be able to find copies of here and there to use as a source also.
« Reply #11 on: June 10, 2022, 01:42:51 PM »
Ty put together lists of Classic legal and N-30 legal designs. I thought they'd be pinned at the top of their respective forums below, but a brief look didn't result in finding them. I'm shocked. But also, considering all the research Ty did on the project(s), I'd bet that he has the list(s), and if he doesn't, Randy Smith probably would.    H^^ Steve
« Reply #12 on: June 10, 2022, 07:21:16 PM »
   The N-30 lists are still there, but I don't recall there ever being a Classic list. Everyone is always looking for the latest and the greatest N-30 design. I still think it's a redundant class and should be limited to 1970's designs.
