  • July 28, 2025, 10:57:33 AM
Author Topic: coroplast glue?  (Read 1720 times)
Offline bob werle
coroplast glue?
« on: March 23, 2013, 11:40:00 AM »
What would be the best way to glue ply or balsa to coroplast?
just trying something and thought it might be fyn.  Will post more if this liiks like anything.
Bob
ama 5871
Offline Noel Corney
Re: coroplast glue?
« Reply #1 on: March 23, 2013, 03:41:38 PM »
Hi Bob ,On Dark side models contact is the glue of choice,You still need to rough up the mating surfaces with 220 or 180 grit.Regards , Noel.
Offline Bootlegger
Re: coroplast glue?
« Reply #2 on: March 23, 2013, 04:48:57 PM »
  I picked up some core plast at a sign shop and have used Duco, carpenter glue, epoxy and slow C A on it and they all worked.
 When I got the c/plast I asked the guy there what kind of glue to use and was told that all these work, HOWEVER your mileage may vary, so check first, and please don't shoot the messenger...
  I have seen some that seemed to be slick also and these glues might not work...
8th Air Force Veteran
Gil Causey
AMA# 6964
Offline Larry Renger
Re: coroplast glue?
« Reply #3 on: March 23, 2013, 05:09:44 PM »
The ET-1s were all assembled with hot-melt glue.  No prep necessary.  I suspect that ZAP Goo would work as well or better.
Offline bill bischoff
Re: coroplast glue?
« Reply #4 on: March 23, 2013, 06:34:38 PM »
US Aircore, the fold up coroplast RC airplane people, always recommended solvent based contact cement. Water based latex contact cement would let go after only a short time.
Offline MikeCoulombe
Re: coroplast glue?
« Reply #5 on: March 23, 2013, 07:09:09 PM »
Here is a link to draftman3 on youtube.
Me I use plumbers or automotive goop for the structure joints such as internal fuse supports, I like Gorilla glue for constructing the spar and gluing same into the wing, for the trailing edge I like to use the flash and zap technique, I flash the glue surfaces with a propane torch, then apply "Dots" of medium zap, clamp in place and walk away for 24hrs.
http://www.youtube.com/user/draftman3?feature=watch
Offline John Cralley
Re: coroplast glue?
« Reply #6 on: March 23, 2013, 08:15:58 PM »
Bob,
As John Hammond stated, "this is probably more than you want to know about Coroplast!"
Go to this link: ]http://spadworld.net/forum/viewtopic.php?t=147]
John Cralley
AMA 52183
Central Illinois
