  • July 28, 2025, 10:57:21 AM
Author Topic: Proto plans? .21, 'B'.  (Read 2113 times)
Offline Mike Lauerman
« on: March 22, 2013, 03:25:49 PM »
In all my searches for plans, I seldom see anything for Protos.
I am especially interested in 'B' Proto, but .21 size would also be desirable for my Taipan engine.
Is there a 'special place' for these to be found?  Chris McMillan maintains that the Protos look like airplanes, and I'm inclined to agree.
(My 'B' T/R planes are coming along)
Offline bob whitney
Re: Proto plans? .21, 'B'.
« Reply #1 on: March 22, 2013, 03:56:56 PM »
i have a few B, & 21 proto plans and a couple of articals
rad racer
« Reply #2 on: March 22, 2013, 04:19:12 PM »
The last .29 proto I recall being published was in MAN about '57, and used a Fox .29R (bathtub intake), I believe. "Fast Miler" or something like that, and I believe the designer was "Rankin" or similar. I designed and built 4ea. .29 protos of my own, all monoline. You're not going to use 2 lines, are you?
Chris Sackett published his .21 Proto "Blondie" in Model Aviation some years ago. Tom Knoppi (F2C Tom) and I wrote the .21 Proto rules, and allowed for a handicap system for using monoline, to be adjusted as required to give parity, based on experience over a season or two of use. We gave the rules to Chris, who was NASS President at the time, and the rules were then FUBAR'd to be 2 line only, so we quit  work on our two planes. Well, that and Tom lost the drawings he'd made!
You know, of course, that any B T/R design is probably perfectly legal for either B Proto or .21 Proto?   H^^ Steve
« Last Edit: March 23, 2013, 08:01:48 PM by Steve Helmick »
Offline pipemakermike
« Reply #3 on: March 22, 2013, 05:08:24 PM »
Here are a couple
PDF Here:- http://www.outerzone.co.uk/plan_files_3/3226/Mile_Master_CL.pdf
PDF Here:- http://www.outerzone.co.uk/plan_files_2/2148/Splinter.pdf
Mike Nelson
« Reply #4 on: March 22, 2013, 05:25:38 PM »
Bob:  Thanks, I'd like to see what you have.
Steve:  Is there a rough copy of the outline of the rules you wrote for Proto? Just to get parameters...
It was Chris Sackett's article that inspired me to chase the Proto design...That Blondie is beautiful!
Two line, when I do fly it I will 'warm up slowly'. (I'm 70, and not as fast as my regular hot rods any more, let alone a Spinning rocket!)
Mike:  Aha! There ARE some... Thanks, that's what I think I'm talking about...and I do see the similarity to Team Racers.
Protos that I saw seemed more...long, and 'scalish'...generally higher aspect ratio than some B/TR.
I appreciate all the answers here!
Offline bob whitney
« Reply #5 on: March 22, 2013, 05:50:35 PM »
 i hate to be a spoil sport, but if you plan on building and  flying a 21,proto especially a rossi 21  build an up right . if u look at all the better proto's and form 40's flying today, they are up right   ,the newer engines like to tourque in on take off
rad racer
« Reply #6 on: March 23, 2013, 08:11:11 PM »
Mike, I looked on the NASS website www.clspeed.com for the rules, and didn't find them. It's possible they might be in the AMA site, but they are not on Flying Lines, 'cause that's the first place I looked. I don't understand how anybody can expect contestants to build planes and show up at the big contests when you can't find the rules. You might ask on the Speed Forum here and see if anybody can post a link or the rules as a .pdf or .txt file.  H^^ Steve
Offline ash
« Reply #7 on: March 24, 2013, 05:03:36 AM »
On the AMA website, linked from the rules page of clspeed.com: http://www.modelaircraft.org/files/2011-2012CLSpeed.pdf
Offline PerttiMe
« Reply #8 on: March 24, 2013, 05:12:01 AM »
This is Blondie. (and the picture is the best I have)
I believe Steve Wilks has Proto material on his CDs.
« Last Edit: March 24, 2013, 06:12:41 AM by pipemakermike »
Mike Nelson
