  • July 06, 2025, 10:01:53 PM
Author Topic: ringmaster  (Read 1847 times)
Offline John KruziK
ringmaster
« on: November 14, 2010, 06:49:17 PM »
Where should the cg be on a ringmaster  Thanks john
AMA 874027
Re: ringmaster
« Reply #1 on: November 14, 2010, 07:01:01 PM »
The easiest answer:  Measure 1/4 of the wing at the root from leading edge and hold the plane at this position. If it's level, fore and aft, it's OK to fly.  If it's "squirrly" flying level, then it's tail-heavy.  If it's hard to change direction on square loops, then it's nose-heavy.
Hardly any plane flies perfectly balanced the first flight.  Adjust the CG until it gets where you like it.
Offline John Cralley
Re: ringmaster
« Reply #2 on: November 15, 2010, 09:25:32 PM »
With all due respect to Floyd, 2 1/2" (the root cord is 10") may be a bit tail heavy to start. I would start out at 1 1/2" to 1 3/4" from the leading edge and move it back until it flies like you want.
John Cralley
AMA 52183
Central Illinois
Offline Allan Perret
  • Proverbs
Re: ringmaster
« Reply #3 on: November 16, 2010, 06:14:20 AM »
Just checked my S1, and it's about 1" from the LE.  It flys real nice..
Allan Perret
AMA 302406
Slidell, Louisiana
  • Gravitywell
Re: ringmaster
« Reply #4 on: November 16, 2010, 09:45:55 AM »
What Allen says.  Only mine aint as purdy as his, so I ain't showen any picture! H^^
Glenn Reach
Westlock, Alberta
gravitywell2011 @ gmail . com
Offline John KruziK
Re: ringmaster
« Reply #5 on: November 16, 2010, 08:16:49 PM »
Thanks guys.    Glen mine doesn't look that good either so no pics.
AMA 874027
