General control line discussion => Open Forum => Topic started by: John KruziK on November 14, 2010, 06:49:17 PM
Title: ringmaster
Post by: John KruziK on November 14, 2010, 06:49:17 PM
Where should the cg be on a ringmaster  Thanks john
Title: Re: ringmaster
Post by: FLOYD CARTER on November 14, 2010, 07:01:01 PM
The easiest answer:  Measure 1/4 of the wing at the root from leading edge and hold the plane at this position. If it's level, fore and aft, it's OK to fly.  If it's "squirrly" flying level, then it's tail-heavy.  If it's hard to change direction on square loops, then it's nose-heavy.
Hardly any plane flies perfectly balanced the first flight.  Adjust the CG until it gets where you like it.
Post by: John Cralley on November 15, 2010, 09:25:32 PM
With all due respect to Floyd, 2 1/2" (the root cord is 10") may be a bit tail heavy to start. I would start out at 1 1/2" to 1 3/4" from the leading edge and move it back until it flies like you want.
Post by: Allan Perret on November 16, 2010, 06:14:20 AM
Just checked my S1, and it's about 1" from the LE.  It flys real nice..
Post by: Glenn (Gravitywell) Reach on November 16, 2010, 09:45:55 AM
What Allen says.  Only mine aint as purdy as his, so I ain't showen any picture! H^^
Post by: John KruziK on November 16, 2010, 08:16:49 PM
Thanks guys.    Glen mine doesn't look that good either so no pics.
