As long as the wife, daughter or grandkids don't delete the program I have not had trouble loading pictures. I down load the card from the digital camera to my pictures in the documents section of the computor. I have Windows something that is working until the wife tries loading a newer version of windows. I come to the forum, start a new post or click on an existing post.
At the bottom of the post is a line "Additional Options", click on it. A line should come saying Attach: with a blank space. Click on the Browse. Should bring up your picture file. Check size of file/picture. Has to be less than 1000KB. If you have multiple files/pictures they need to be less than 200KB for 5 items. The Attach shows that a max of 20 items as long as they don't add up to 1000KB. My program has an edit in whitch I can resize. I have to go 20% to get my items to size. Click on the item you want to post. The blank line in your pictures should have a location for your pic. There is a box in my program that you click on to tell wat type file you have. Then click on open. If you want more pics, click on more attachments. I learned a lot of this by trial and error. I too have some posts out in cyber space floating around. Hope this helps a little. At first it was very complicated for this old man. As time goes on it gets easier.
PS:The attached was sent to me on Veterans Day. jeh
