Link 1
Stunt Hangar YouTube
P.A.M.P.A.
AMA
Balsa Density Calculator
This topic
This board
Entire forum
Google
Home
Help
Tags
Advertise
Login
Register
July 06, 2025, 08:23:41 AM
1 Hour
1 Day
1 Week
1 Month
Forever
stunthanger.com
Open Forum
(Moderators:
RandySmith
Steve Berry
blank
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: blank (Read 1328 times)
Motorman
Trade Count:
0
Admiral
blank
on:
August 23, 2013, 11:22:05 AM »
blank
Last Edit: September 10, 2021, 07:51:16 AM by Motorman
Logged
Bill Little
2017
Trade Count:
0
Admiral
Second in COMMAND
Re: Brodak Profile Tanager (Bellcrank)
Reply #1 on:
August 23, 2013, 11:49:48 AM »
Hi Walt,
If you are actually getting 20* and 30* then I would say that hole is the one to use. You may never use the full throws, but then in panic mode it would be there......
BIG Bear
RNMM/AMM
Logged
Big Bear
AMA 95351 (got one of my old numbers back!
Allen Eshleman
Trade Count:
0
Captain
Reply #2 on:
August 23, 2013, 09:03:32 PM »
What engine do you have on the Tanager?
Logged
john e. holliday
25 supporter
Trade Count:
0
Admiral
Reply #3 on:
August 24, 2013, 09:00:00 AM »
Your wrist movement and the handle spacing to me decides how much bell crank movement you get when flying a CL plane. I too try to get as much bell crank movement as I can. That means that some times the middle hole is too far from the pivot point. I had a Dolphin that the flaps/elevators were max 25 degrees and was too quick for me. Balance has a lot to do with it also.
Logged
Shawnee, KANSAS 66203
AMA 23530 Have fun as I have and I am still breaking a record.
Steve Helmick
24 supporter
Trade Count:
0
Admiral
Reply #4 on:
August 24, 2013, 05:24:41 PM »
How long is the flap horn? That determines where you attach the BC/flap pushrod (top hole). The BC attachment point should be shorter than the top hole on the flap horn, never longer.
Logged
In 1944 18-20 year old's stormed beaches, and parachuted behind enemy lines to almost certain death. In 2015 18-20 year old's need safe zones so people don't hurt their feelings.
Steve Helmick
24 supporter
Trade Count:
0
Admiral
Reply #5 on:
August 24, 2013, 09:22:39 PM »
Use a wider handle spacing! Sounds good to me, 'cause the wider the handle spacing, in theory, your precision improves. If you are using a "TED handle", you can reverse the stainless steel legs to widen the spacing.
Logged
Print
Pages: [
1
Go Up
« previous
next »
stunthanger.com
Open Forum
(Moderators:
RandySmith
Steve Berry
blank
