General control line discussion => Open Forum => Topic started by: Motorman on August 23, 2013, 11:22:05 AM
Title: blank
Post by: Motorman on August 23, 2013, 11:22:05 AM
blank
Title: Re: Brodak Profile Tanager (Bellcrank)
Post by: Bill Little on August 23, 2013, 11:49:48 AM
Hi Walt,
If you are actually getting 20* and 30* then I would say that hole is the one to use.  You may never use the full throws, but then in panic mode it would be there......
BIG Bear
RNMM/AMM
Post by: Allen Eshleman on August 23, 2013, 09:03:32 PM
What engine do you have on the Tanager?
Post by: john e. holliday on August 24, 2013, 09:00:00 AM
Your wrist movement and the handle spacing  to me decides how much bell crank movement you get when flying a CL plane.   I too try to get as much bell crank movement as I can.   That means that some times the middle hole is too far from the pivot point.  I had a Dolphin that the flaps/elevators were max 25 degrees and was too quick for me.   Balance has a lot to do with it also.
Post by: Steve Helmick on August 24, 2013, 05:24:41 PM
How long is the flap horn? That determines where you attach the BC/flap pushrod (top hole). The BC attachment point should be shorter than the top hole on the flap horn, never longer.  H^^ Steve
Post by: Steve Helmick on August 24, 2013, 09:22:39 PM
Use a wider handle spacing! Sounds good to me, 'cause the wider the handle spacing, in theory, your precision improves.  If you are using a "TED handle", you can reverse the stainless steel legs to widen the spacing.  #^ Steve
