The beginner pattern is a takeoff and a wingover. Everything else is just bonus points, but it's the wingover that puts you on the scoreboard.
Inside loop first. It's in the rule book. Start into the wind as for a wingover, do an inside loop, an outside loop, repeat, then finish the wingover. If the wind isn't too bad then do the eight low; it'll be easier.
