  • June 16, 2025, 10:51:29 PM
Author Topic: OS 46 FX for control line  (Read 2318 times)
Offline James C. Martin
« on: May 09, 2014, 06:25:11 PM »
are there any other 0S 46 fx engines bieng used for control line? I have a new in the box one I purchased years ago and got the venturi and needle and spraybar  from a OS SFS 46 still need to bench test this any opinions on this set up?
Offline Bill Barber
Re: OS 46 FX for control line
« Reply #1 on: May 11, 2014, 02:27:55 PM »
 I have a OS.46 FX  also and haven't used it yet . I did a search here on Stunt Hanger
and found a lot info on .46FX , just type in in the search section  OS .46 FX .
   Cheers Bill
AMA 325076
« Reply #2 on: May 12, 2014, 09:04:31 AM »
I have an OS 46 F series of engine.   Will have to pull it out of the stash and see which one it is.  I know it weighs a ton.  It will be going into Don Hutchison design I got from Jim Snelson when he had it at VSC.   By the way the engine ran great in the plane and was very easy to needle.
Offline MarcusCordeiro
« Reply #3 on: May 12, 2014, 12:50:19 PM »
I have used one and though it's really heavy,it ran OK.
Problem was the inside of the sleeve started to chip off and then it cracked... One friend had a similar problem, but our engines were used already.
Low pitch and hi RPM...
Please, post your results...
Marcus
Live to fly, fly to live
Aces High!
Here comes Marcus, man..."
« Reply #4 on: May 12, 2014, 03:52:04 PM »
Marcus
This was a common problem with the FX. "Supposedly" the AX line fixed that problem.
Offline Curare
« Reply #5 on: May 12, 2014, 03:59:23 PM »
It was more of a problem with the SF series. I have a 61SF that had a seriously flaky liner. Still runs ok though, just a little wimpier than before. If I recall correctly they were the last true ABC motors.
All the FX's I've had have had fairly solid plating, but I believe they're ABN.
Greg Kowalski
AUS 36694
Offline Garf
    • Hangar Flying
« Reply #6 on: May 12, 2014, 04:37:38 PM »
What is the difference between the FX and the FSR?
Offline Andrew Saunders
  • 2013 Nats
« Reply #7 on: May 12, 2014, 06:46:47 PM »
Dont use the OS MAx neddle valve assembly. Use a Super tigre needle valve assembly. Youll get a better run and a finer adjustment on the RPMs.
