  • July 17, 2025, 12:41:16 PM
Author Topic: Where to find 4-40 pressure taps?  (Read 1354 times)
Offline frank mccune
« on: April 10, 2016, 03:40:53 PM »
    Hi All:
    Where may I purchase some of these things?
                                                               Tia,
                                                               Frank McCune
Offline Dane Martin
  • heli pilot BHOR
Re: Where to find 4-40 pressure taps?
« Reply #1 on: April 10, 2016, 04:44:33 PM »
http://www.radicalrc.com/item/Bolt-On-Pressure-Fitting-4-40-by-Fox-105485
Fox made them, but I'm pretty sure k&b used that size. Check out mecoa.com also
Offline Balsa Butcher
  • High Desert Flier
« Reply #2 on: April 11, 2016, 09:01:02 PM »
Fox 4/40 pressure taps are getting hard to find but the 6/32 Dubro ones are available and work fine. If one is concerned about the opening being too large, (it's not) however if it is, a restrictor can be put in the system. One way to make one is to fill up a short length of 1/8" brass tube with solder. JB Weld will also work. Drill a small hole in the center. Shove it into the line connecting the pressure tap to the uniflow outlet. Easy, adjustable, and removable.  8)
Pete Cunha
Sacramento CA.
AMA 57499
