Engine basics => Engine set up tips => Topic started by: frank mccune on April 10, 2016, 03:40:53 PM
Hi All:
Where may I purchase some of these things?
Tia,
Frank McCune
http://www.radicalrc.com/item/Bolt-On-Pressure-Fitting-4-40-by-Fox-105485
Fox made them, but I'm pretty sure k&b used that size. Check out mecoa.com also
Fox 4/40 pressure taps are getting hard to find but the 6/32 Dubro ones are available and work fine. If one is concerned about the opening being too large, (it's not) however if it is, a restrictor can be put in the system. One way to make one is to fill up a short length of 1/8" brass tube with solder. JB Weld will also work. Drill a small hole in the center. Shove it into the line connecting the pressure tap to the uniflow outlet. Easy, adjustable, and removable. 8)
