  • July 08, 2025, 07:49:52 PM
Author Topic: Remote needles  (Read 3296 times)
Offline Russell Shaffer
Remote needles
« on: February 16, 2007, 08:30:26 PM »
What opinions do you all have about remote needle valves?  I am specifically interested in a Fox conversion to get my fingers away from that short, stiff needle.  Fox sells a pretty reasonably priced remote needle and spraybar set, but how does it work in the real world?  I have a couple of old engines that really need new needles anyhow, and Fox'es setup is about as cheap as buying standard replacements. Or should I buy replacement OS or Supertiger assemblies, or new Fox stuff?  Thanks and all advice appreciated.
Russell Shaffer
Klamath Falls, Oregon
Offline Joe Messinger
Re: Remote needles
« Reply #1 on: February 17, 2007, 10:05:22 AM »
Russell,
Since no one to date has responded to your question, I thought I would offer my opinion/experiences with RNV set up, for whatever it's worth.
Allot has been discussed on this subject and, as is the case with most things, a variety of opinions have been expressed.
My experience with RNVs on profile planes has has been this:  The engine run is good until all but the the last ounce or so of fuel has been used up.  the engine then speeds up and slows down repeatedly.  Eight to fifteen laps follow like this before the engine finally stops.  Very annoying and would be disastrous in a competitive situation. It's not very good for the engine either.
By changing the RNV to a standard, through the venturi NVA, the problem ended.  No other changes made.  One lap of increased rpms, a burp or two  and shut down.
I use a Sullivan 4oz. plastic tank.  Sintered bronze clunk with a fill tube from the bottom (inside) of the tank to above the top (outside) and a vent tube from top (inside) to below (outside) the tank.  Maybe a Uniflow tank would act differently.  I can't say because I haven't tried one.  My fuel supply system as described above works very well for me so I see no need to change it.
I haven't tried a RNV on any upright or inverted engines so I can't say how the RNV works on them.  I would speculate that the results might be the same as with a side mount.
I'm sure there are many who have not experienced problems with RNVs.  Perhaps someone who has had good luck with them can offer their advice.
Joe
Joe Messinger
Re: Remote needles
« Reply #2 on: February 17, 2007, 06:20:11 PM »
Hi Russell,
Sorry, but I have never used the remote NVA.  As of yet I have not seen one in use, so I can't say how it works at all.
If you go with a "aftermarket" NVA, get Randy Smith's (Aero Products) PA NVA that is made for the Fox 35.  Best NVA's on the market!
Offline Keith Spriggs
    • khspriggs
Re: Remote needles
« Reply #3 on: February 18, 2007, 12:18:17 AM »
Not a remote needle valve and not a new idea, The flexible cable is a piece of 1/16 inch cable from the hardware store. knob and connector are home made.  Silver brazed together. Works great and gets your hand away from the prop. Since I made this I discovered that the three inner layers from an old speedometer cable works even better than the 1/16 inch cable. More flexible and designed for torque.
Offline rustler
Re: Remote needles
« Reply #4 on: February 18, 2007, 03:00:57 AM »
I have flown a G A Special with side mounted LA40 and stock factory remote NVA. Plastic clunk tank. No problems. Perfect run. So far no one has come up with any explanation as to why a remote should run any different from a front mounted needle. I'd be interested to see such an explanation.
Ian Russell.
Offline Dick Fowler
Re: Remote needles
« Reply #5 on: February 18, 2007, 05:49:12 AM »
I've seen both setups and one of my friends, Roger, can get great runs on remote needles, wired open RC carbs, popsicle sticks for venturis, you name it. I would think that muffler pressure would be of help if a remote needle is used. I'm thinking of the "inventory" of fuel after the needle valve that is being drawn against the restriction of the needle has no head pressure when the fuel pick up in the tank becomes exposed. Adding muffler pressure might be the variable.
Dick Fowler AMA 144077
Kent, OH
Re: Remote needles
« Reply #6 on: February 19, 2007, 06:04:28 AM »
Hello,
Only speculation but I would hazard a guess that problems associated with remote needle valves might have something to do do with an overall reduction in the ability of the system to draw fuel from the tank.
Being that this isn't consistant and some have no difficulties with the remote set up, perhaps slight variables in the entire system create the trouble.  If the RNV does create somewhat more of a restriction than a conventional NVA, an inconsistent run occurs.  Not considering the needle valve, if everything else within the plumbing is without fault, no problems result.
I've never tried using muffler pressure with a RNV.  Perhaps that would compensate for any slightly reduced fuel draw if that is a characteristic of a RNV.
Joe
Joe Messinger
Offline rustler
Re: Remote needles
« Reply #7 on: February 20, 2007, 03:33:36 AM »
Hi. I can't see any reduction in ability to draw fuel. The fuel passes theough the same length of fuel tube, and is metered by a needle valve that is set to deliver the correct amount of fuel in both systems.
Ian Russell.
Re: Remote needles
« Reply #8 on: February 20, 2007, 04:12:32 AM »
*Through the venturi NVA: Fuel is delivered to the the spray bar at full volume.
*RNV: Fuel is delivered to the the spray bar at reduced volume.
Again, just speculation???
Joe
Joe Messinger
Offline Dick Fowler
Re: Remote needles
« Reply #9 on: February 20, 2007, 05:47:51 AM »
At first blush that seems right, but consider what happens with a RNV when air reaches the needle and there remains that inventory of fuel I spoke of earlier. The needle is now metering a much lower viscosity fluid (air) while fuel is still being supplied to the engine.
Kent, OH
Re: Remote needles
« Reply #10 on: February 20, 2007, 10:26:01 AM »
Hi Russell
The only problem I have had when trying them is the motors do not cycle as well , they sort of make the motor dumb...  If you trying to 4\2 back and forth it is aproblem, if your running a  wet 2  or  solid 4 cycle it most likley will not  be  any problem.  If you want the motor to cycle back and forth fast, you may want to use the front mount.
Another thing is they tend to sometimes get strange running spurts at the very end of the tank
Offline rustler
Re: Remote needles
« Reply #11 on: February 21, 2007, 01:44:26 AM »
I'm sure air in the system would behave differently, but I guess I'm considering a system that doesn't contain any air.
This question interests me, I/m wondering if it might be one of those folk myths that invade our thinking from time to time, like position of belcrank affects how the plane flies.
Ian Russell.
Offline don Burke
Re: Remote needles
« Reply #12 on: February 22, 2007, 10:09:40 AM »
I think we need to remember that the fuel is a fluid column. Pressure in a fluid is a constant end to end from basic hydrodynamics.  A needle valve in a system will introduce a restriction in that system but no matter where it is it has the same effect on that system.  The restriction will reduce (regulate) the flow, but will not reduce the pressure.
I feel that if one has problems with a remote needle valve system there is some other related problem other than the location of the valve.  Problems I've had have been air leaks introduced by the design of the needle assy.  Get rid of the leaks, get rid of the problem.
don Burke AMA 843
Menifee, CA
Re: Remote needles
« Reply #13 on: February 22, 2007, 10:16:45 AM »
Hi Don  the ones I have tried had  zero leaks, you need to remember  also what you wrote  above   """"The restriction will reduce (regulate) the flow, but will not reduce the pressure. """
An engine cycling 4-2 is affected  from  not only  pressure but also flow, cut the flow and it can make the motor break much leaner or  quicker  or  longer, increase the flow it can break slower, later or not at all . If it was  only pressure  we  could put the NVAs in the tank or at the front of the tank.  This works very rarely  and  if your  wanting a motor that depends on fast cycling 4-2 it many times ,retards that type of cycling motor run
Offline Dick Fowler
Re: Remote needles
« Reply #14 on: February 22, 2007, 07:04:23 PM »
Not true. As a fluid passes through a restriction there is a drop in pressure across the orifice (restriction). The pressure on the exit side of the needle will be less than before the needle. The  exit side pressure (after the remote needle) is close to the inlet pressure of the engine which is below atmospheric pressure during the time the intake is open.  Another little problem is that fluid is drawn in short burst as the intake pressure varies between atmospheric and the lower intake pressure as the intake opens. The inertia of the fluid in the tubing after the remote needle and the flexibility of the tubing probable causes some "pulsing" of the tubing which results in wasted energy and reduction of flow response to the change in pressure at the intake. Remember the tubing after the RNV is surrounded by atmospheric pressure and the inside is below that. Rigid plumbing might also help the response problem but you still have inertia and reduced pressure of the fuel at the intake.
Kent, OH
Re: Remote needles
« Reply #15 on: February 22, 2007, 07:22:11 PM »
Hello Dick
My point was trying to point out that  there is more happening than just one thing, and that Myself and others have tried the remote NVAs without the results we wanted, and that by moving the needle to the venturie it did  much improve the engine run. I have no reason to want to argue about other things that may or may not be  happening
Offline Dick Fowler
Re: Remote needles
« Reply #16 on: February 22, 2007, 07:31:11 PM »
Hello Dick
My point was trying to point out that  there is more happening than just one thing, and that Myself and others have tried the remote NVAs without the results we wanted, and that by moving the needle to the venturi it did  much improve the engine run. I have no reason to want to argue about other things that may or may not be  happening
Randy, I think what I wrote was in complete agreement with and is a plausible explanation for your experience. My personal experience with RNV's is the same as yours... OK if you don't expect much.
Kent, OH
Alan Hahn
Re: Remote needles
« Reply #17 on: February 22, 2007, 07:41:11 PM »
Dick,
I agree with you that once the air hits the needle seat, the low viscosity air will leak past so fast that the engine will or should go pretty rich. However that will last only as long as the amount of fuel in the tubing between the needle and the spraybar. That might be a lap or two, but not much more than that (not the 10 to 15 someone else mentioned that they were seeing.
Otherwise the pressure in the line past the needle will be less simply because the fuel flowing past the needle restriction causes the pressure drop. But other than the effect in the first paragraph, I  have a hard time understanding why a remote should behave different from  the standard. Remember in the standard needle assembly, the fuel between the needle seat and the spraybar opening is also at the same low pressure.
