  • June 21, 2025, 11:30:17 PM
Author Topic: New Fox .60 stunt engine  (Read 1528 times)
Offline Ty Marcucci
« on: December 16, 2007, 01:32:53 PM »
 H^^
« Last Edit: August 15, 2017, 05:15:56 PM by Ty Marcucci »
Ty Marcucci
Offline mike mullis
Re: New Fox .60 stunt engine
« Reply #1 on: December 16, 2007, 03:05:26 PM »
there is or was one on ebay.....buy it now for 260.00  i think............
Mike Mullis        LaVergne,Tennessee
Offline Jim Oliver
« Reply #2 on: December 16, 2007, 03:35:39 PM »
Ty,
I just posted weight and measurements of the Fox Stunt 60 on the Brotherhood of the Ring site.
 www.brotherhoodofthering.info/flightline/forums/thread-view.asp?tid=765&posts=19&start=1
Scroll down the page a bit for the info.
Jim
Jim Oliver
AMA 18475
Offline Gordon Tarbell
« Reply #3 on: December 16, 2007, 07:50:31 PM »
Couldn't access the site . I am not worthy.
Gordon Tarbell AMA 15019
« Reply #4 on: December 16, 2007, 08:36:36 PM »
Anyone seen or tried the new Fox .60 CL engine?  Or is it too new?  A new, made in the USA, H^^ stunt engine! wow y1
Hello TY
I have, I have the FOX 60  in stock
I also have the new FOX 35 Plasma  engines in stock also
Offline Jim Oliver
« Reply #5 on: December 16, 2007, 08:39:19 PM »
The short version:
Weight of engine------------------------------------------------------12.75 oz.
Weight of muffler-------------------------------------------------------2.75 oz.
Width of case below mounting lugs--------------------------------------1.558
Width of lugs-----------------------------------------------------------2.278
Width between mounting holes, center to center-------------------------1.945
Distance between mounting holes, front to back, center to center---------0.995
over all length from back of engine to face of prop drive washer-----------3.60
Length of prop shaft----------------------------------------------------0.895
Shaft size-------------------------------------------------------------5/16 x 24
Height of engine, to top of fins------------------------------------------3.842
Baffle aluminum piston, no ring
Rod bushed at crankpin with oil slot, don't know about wrist pin end
Head button with deep hemi configuration
Jim
Jim Oliver
AMA 18475
Offline mike mullis
« Reply #6 on: December 18, 2007, 06:50:33 AM »
randy..whats the price of the fox .60?????
Alan Hahn
« Reply #7 on: December 18, 2007, 07:58:45 AM »
You can check out the Fox site on that.
http://www.foxmanufacturing.com/
« Reply #8 on: January 09, 2008, 11:47:54 AM »
Hello Mike
I sell them for  $249.00
