Engine basics => Engine set up tips => Topic started by: Ty Marcucci on December 16, 2007, 01:32:53 PM
H^^
there is or was one on ebay.....buy it now for 260.00 i think............
Ty,
I just posted weight and measurements of the Fox Stunt 60 on the Brotherhood of the Ring site.
www.brotherhoodofthering.info/flightline/forums/thread-view.asp?tid=765&posts=19&start=1
Scroll down the page a bit for the info.
Jim
Couldn't access the site . I am not worthy.
Anyone seen or tried the new Fox .60 CL engine? Or is it too new? A new, made in the USA, H^^ stunt engine! wow y1
Hello TY
I have, I have the FOX 60 in stock
I also have the new FOX 35 Plasma engines in stock also
The short version:
Weight of engine------------------------------------------------------12.75 oz.
Weight of muffler-------------------------------------------------------2.75 oz.
Width of case below mounting lugs--------------------------------------1.558
Width of lugs-----------------------------------------------------------2.278
Width between mounting holes, center to center-------------------------1.945
Distance between mounting holes, front to back, center to center---------0.995
over all length from back of engine to face of prop drive washer-----------3.60
Length of prop shaft----------------------------------------------------0.895
Shaft size-------------------------------------------------------------5/16 x 24
Height of engine, to top of fins------------------------------------------3.842
Baffle aluminum piston, no ring
Rod bushed at crankpin with oil slot, don't know about wrist pin end
Head button with deep hemi configuration
Jim
randy..whats the price of the fox .60?????
You can check out the Fox site on that.
http://www.foxmanufacturing.com/
Hello Mike
I sell them for $249.00
Regards
