  • June 26, 2025, 04:02:11 AM
Author Topic: Prop washer for LA 40  (Read 854 times)
« on: November 18, 2011, 09:28:47 PM »
Any one know if I can find a prop washer at a hardware store?
Offline Dennis Moritz
Re: Prop washer for LA 40
« Reply #1 on: November 18, 2011, 10:23:31 PM »
Steel washer with a 1/4" hole, roughly the diameter of the drive washer, should work. Nice prop washers seem to have a taper thinning as you move from the center to the circumference. Perhaps it distributes forces better.
Offline Douglas Ames
« Reply #2 on: November 18, 2011, 10:56:02 PM »
I have several. They are pretty much standard for all OS's with 1/4-28 shaft. PM me your address and I'll pop one in the mail.
« Last Edit: November 19, 2011, 08:05:33 AM by Douglas Ames »
AMA 656546
« Reply #3 on: November 19, 2011, 07:37:50 AM »
Thanks Douglas!!!!!!
PM sent !
« Reply #4 on: November 19, 2011, 08:17:16 AM »
"In the mail" as they say...OS nut & washer included.
AMA 656546
« Reply #5 on: November 19, 2011, 12:38:12 PM »
If I'm not installing a spinner, I always replace the OS prop nut with a Gr.8 from the hardware store that has an SAE hex...7/16" wrench...I think. OTOH, if I'm installing a spinner, then often use a Dave Brown (short) extension prop nut/washer combo, or use the stock OS washer with a 1/4-28 coupler nut from the hardware store. I'm not too keen on aluminum prop nuts. If they strip out at the wrong time, it's a problem I don't need.  H^^ Steve
