  • June 22, 2025, 07:57:28 PM
Author Topic: ...muffler  (Read 2362 times)
Offline Bootlegger
...muffler
« on: December 01, 2010, 11:14:45 AM »
   H^^    Fellow's I have an old Fox 29 and want to put a muffler on it what do y'all suggest and why??
  Thanks, Gil    D>K
8th Air Force Veteran
Gil Causey
AMA# 6964
Offline Garf
    • Hangar Flying
Re: ...muffler
« Reply #1 on: December 01, 2010, 01:20:36 PM »
This is my answer to mounting a muffler on old Fox engines. It will work on a variety of others.
Re: ...muffler
« Reply #2 on: December 01, 2010, 11:23:04 PM »
Garf :  y1
Offline Bill Heher
  • Fix-it
Re: ...muffler
« Reply #3 on: December 02, 2010, 06:46:30 AM »
Note of caution, Fox .19 / .29 / .35 Stunt engines have pretty lightweight cases.
 When using a strap on type muffler as shown described have a prop on the engine and keep turning it over frequently to check for binding as you tighten the screws securing the muffler strap.
Cranking down too hard can squeeze the case / liner enough to cause a slight bind, that can result in hot running, increased wear, inconsistant runs, etc.
Bill Heher
If it's broke Fix-it
Offline Terrence Durrill
Re: ...muffler
« Reply #4 on: December 02, 2010, 06:14:45 PM »
Ty, can you post a picture of your setup with threaded rod for the muffler holddown.  Sounds like something I would like to try.............TDurrill    y1
Offline Ward Van Duzer
Re: ...muffler
« Reply #5 on: December 03, 2010, 09:09:24 AM »
Or ask Bigiron if he has any of those machined straps for foxes. They don't put pressure or stresses on the crankcase. Really cool!
W.
Offline Bill Heher
  • Fix-it
Re: ...muffler
« Reply #6 on: December 05, 2010, 12:35:36 PM »
I like the wood block Ty - simple, light, and cheap!  3 of my favorite things!
Bill Heher
Offline Garf
    • Hangar Flying
Re: ...muffler
« Reply #7 on: December 06, 2010, 11:09:11 AM »
W.
Fox made a muffler a long time ago that used a cast piece that matched the back of the case precisely. If I can find mine, I'll post a pic of it.
Re: ...muffler
« Reply #8 on: December 07, 2010, 10:11:28 AM »
Two more photos.   The wood block is to keep the threads from damaging the case.
Ahhhh. Ty, a great looking 1954 version Fox 25!  (you know I like those little things  H^^ )
Big Bear
