  • June 25, 2025, 01:51:27 PM
Author Topic: Fox 15 BB bearings ?  (Read 908 times)
Offline YakNine
« on: August 15, 2011, 10:43:58 AM »
Hey guys does anyone know the bearing numbers for a fox 15 BB or are these a propriatary item to Fox. Thanks T.J.
AMA 85135        GSCB
Re: Fox 15 BB bearings ?
« Reply #1 on: August 15, 2011, 11:46:48 AM »
Have you asked Boca Bearing yet?
Custom bearings are exceedingly expensive; I can't imagine even a high-volume place like OS getting a bearing that is so far from standard as to have unique sizes.  Different seal or precision options, yes.  Entirely different sizes -- egad!  Chances are that they're a common inch-size standard, and your only challenge in ordering them from a catalog would be getting the right options in quality and seals.
Offline YakNine
« Reply #2 on: August 15, 2011, 12:18:00 PM »
Thanks, Tim I went to their site and found just what I was looking for . T.J.
AMA 85135        GSCB
Offline Mike Greb
« Reply #3 on: August 16, 2011, 04:20:44 PM »
Fox 15 bearings are no problem.  Just be glad you are not trying to find Rossi15 MK2 rear bearings.
