  • June 21, 2025, 01:30:52 AM
Author Topic: PA 61  (Read 802 times)
Offline James Mills
PA 61
« on: August 16, 2011, 07:30:50 PM »
Randy,
I put a run on my PA 61 in my new Legacy.  Had a hard time getting it to start, kept opening up the needle.  Once I got it to start it seemed to be running okay, a bit fast but not all out.  It ran a couple of ounces and then died and had smoke pouring off the head and case and had zero compression immediately after the run (it has come back some).  Is the motor toast?
James
AMA 491167
Re: PA 61
« Reply #1 on: August 16, 2011, 09:03:10 PM »
Randy,
James
Hi James
I would need to see the motor
Let me know what If I can help
Offline James Mills
Re: PA 61
« Reply #2 on: August 16, 2011, 11:06:22 PM »
Thanks Randy, there is compression again.  I'll try to run it again later (if it's burnt I guess it won't hurt it any more would it)?
James
AMA 491167
