  • July 19, 2025, 05:47:15 PM
Author Topic: OS LA 46 aluminum replacement backplate  (Read 1000 times)
Offline Rafael Gonzalez
« on: August 16, 2011, 12:33:55 AM »
I am posting this after a search yielded some results. I do not know if they are being produced. The original was posted on the Open forum. I believe that it belongs here much better.
 Re: Big oops on backplates.
« Reply #6 on: August 15, 2011, 09:21:41 PM » Quote Modify Remove
Hello!
I did a search on the LA backplate and found this thread. I just bought one (LA .46 C/L)for the first time at the LHS. I ran it on a test plane and could see bubbles emerging from the plastic backplate mating face to the crankcase    Are you still making these? If not,
is there any outfit that retrofits the plastic POS backplate to a normal aluminum?
Regards!
 H^^
Offline Curtis Shipp
  • AMA 753063 / Advanced Stunt Flyer Finally
Life is to short to be sour.
Re: OS LA 46 aluminum replacement backplate
« Reply #2 on: August 16, 2011, 07:49:52 AM »
THANK YOU! SENT EMAIL!
