  • June 22, 2025, 05:51:06 AM
Author Topic: Saito 30 prop choice  (Read 765 times)
Offline Gordon Tarbell
« on: August 05, 2007, 10:52:56 PM »
Would a master airscrew 10-7 3blade be a good starting place for the saito 30 on the primary force arf. I will start with 10-22 fuel (50-50) .
Gordon Tarbell AMA 15019
Offline Bob Zambelli
Re: Saito 30 prop choice
« Reply #1 on: August 06, 2007, 06:54:25 AM »
Hi, Gordon - although I have not tried the prop in question, It sounds like it may be a bit much but, I suggest you give it a try.
I have been experimenting with the SAITO .30 for the last 7 or 8 years and tried quite a few different props.
To date, I have used this little jewel to power a Nobler, Sterling Mustang, Ringmaster, ARF Cardinal, Little Cherokee, Argus and The Plane. I have tried props from 9-6 up to 11-5, just about every brand and material - EXCEPT carbon fiber.
The two that have given the consistently best results are the Master Airscrew 9 1/2-6 and the APC same size.
The APC seems to have a performance edge (pun intended - be carefull).
The Argus with the SAITO .30, 9 1/2-6 APC and Eagle-Hopper tank is my all-time favorite stunt setup.
