  • June 22, 2025, 10:21:04 AM
Author Topic: Super Tigre 40 Venturi  (Read 962 times)
Offline taildragger-j3
  • Me over 1/2 century ago with my Ringmaster Jr.
« on: August 05, 2007, 09:17:47 AM »
Does anyone know if the venturi for the ST .51 or .34 C/L engine will fit in the .40 R/C engine. I have a 40 I'd like to convert for C/L and was hoping one of the standard venturis would fit.
David Strawn
Aggieland, TX
AMA - 10212 (original!)
Re: Super Tigre 40 Venturi
« Reply #1 on: August 05, 2007, 11:42:06 AM »
I'm sure someone will correct me if I'm wrong, but the G51 and G40 use the same carburator, so the venturi's should interchange.
Offline Glen Wearden
« Reply #2 on: August 05, 2007, 03:39:52 PM »
I'm using a venturi in my G51 that I had in my GS40 before I converted it back to RC.  Same animal; not sure about the G34.  Glen
Glen Wearden
Offline Joe Messinger
« Reply #3 on: August 05, 2007, 04:06:01 PM »
Even though Tower Hobby's "Tech Staff" says the ST .51 venturi won't work in a ST .40, they fit just fine.
Joe
Joe Messinger
« Reply #4 on: August 05, 2007, 04:35:05 PM »
Y'all are too much. I knew I could get an answer here muy quick.
Thanks!!
David Strawn
Aggieland, TX
