  • July 18, 2025, 12:33:05 AM
Author Topic: odball Fox 35 on Ebay  (Read 1290 times)
Offline YakNine
« on: June 19, 2012, 06:48:33 AM »
While trolling ebay for goodies I saw an RC version of the 35 stunt engine it even has the 3 bolt backplate was this factory or something home brewed? Search for Fox 35 r/c
AMA 85135        GSCB
Re: odball Fox 35 on Ebay
« Reply #1 on: June 20, 2012, 04:31:20 PM »
Two NV's? I've seen some '50's engines with two NV/spraybars, but never messed with one, and don't know how well they worked. There was no flapper on either venturi or exhaust, nor anything like we'd call a carburator.
How about providing a link?   H^^ Steve
Edit: If this is the one you're referrring to:  http://www.ebay.com/itm/VINTAGE-FOX-35-W-MUFFLER-R-C-GLOW-AIRPLANE-ENGINE-USED-/180907572745?pt=Radio_Control_Parts_Accessories&hash=item2a1eee7e09
All I can say is aw, heck NO! The bozo just put R/C in the title to get more hits, and it looks (due to the muffler ears) isn't really all that elderly. That's 40th Anniv. stuff, I think (but I'm not a Fox spurt). I am wondering why the bypass doesn't have the "40th Anniv." logo, tho, and have no idea what sort of muffler that is.
« Last Edit: June 20, 2012, 05:06:14 PM by Steve Helmick »
Offline kenneth cook
« Reply #2 on: June 20, 2012, 05:53:29 PM »
         That Fox is a early 80's version prior to the 40th anniversary edition. I have some that run quite well and others that are so so. The muffler is a Fox muffler which works a heck of a lot better than the worthless tilt down muffler that just makes your Fox overheat. That particular muffler alone has sold for more than what entire engines go for. The muffler in the picture will eventually fall apart when the back falls off and the guts get shaken out. Pop rivets or small screws can hold the back on reliably. Remove the internal baffle like element and you'll have a muffler that is lighter and functional. The other nice thing about the muffler is that it doesn't butt the exhaust flange it goes all the way over it. Not only that it fits snug and combined with a hose clamp for attachment it will fit all Fox.35's except for the 50 th & 60 th cases. Ken
Offline Douglas Ames
« Reply #3 on: June 20, 2012, 06:23:06 PM »
http://www.ebay.com/itm/Fox-35-Compression-Very-strong-clean-RC-Plane-Engine-/130715035007?pt=Radio_Control_Parts_Accessories&hash=item1e6f39257f
Looks like a home shop conversion, probably a .25 carb.
AMA 656546
Offline YakNine
« Reply #4 on: June 20, 2012, 06:52:59 PM »
That's kind of what I was thinking the front muffler lug looks like it was ground off to make clearance for the carb probably using the over & under mounts and the carb mount looks like a 15bb
AMA 85135        GSCB
Offline YakNine
« Reply #5 on: June 20, 2012, 06:58:13 PM »
Sorry Steve its hard to get fancy with the tiny browser on my phone!
AMA 85135        GSCB
Offline L0U CRANE
« Reply #6 on: June 22, 2012, 04:34:26 PM »
Yeah, it looks a bit cobbled together around the carb bolt-on flange, and ground away for access to the carb mount screws.
??Cut off the stock Fox 35 venturii, heli-arc'ed a platform for the carb?? (...WHY???...)
And, the carb is from a 4-bolt backplate 19-25; it is rectangular. The schneurle Fox 15 carb mount is not rectangular, more a rounded lozenge shape.
\BEST\LOU
