aka - Annular Discharge ...which is the most efficient form of a booster venturi in a carburetor.
Which is apples compared to oranges, we don't run carburetors, nor do we have booster venturies inside of venturies, and if we did there would still be 1 main feed to the inside booster venturie.
Although this would make for a very interesting exercise to make a venturie with a booster inside of it. Someone needs to take on that chore and report back to us
There were many downsides to the Super Tiger Sprinkler venturie
1 was the machined step halfway down, this worked but not nearly as well as a real , or conventional venturie made with the proper angles
2 was the very tiny holes you needed to keep the fuel from dribbling..if the holes are made larger the fuel does not come out of the multiple holes very well, same thing happens if you make a main hole way too large. The same thing happens when people drill out true venturies into straight tubes...they loose the fuel feed pressure and the fuel will dribble out of the side.
3 The tiny holes needed to use in the sprinkler would stop up much much easier than 1 larger hole, especially if you used castor fuel.
4 Super Tiger used, and you needed a complete ditch cut all the way around the outside of the venturie for the fuel to flow all the way around in order to feed the 360 degree holes, this got mix with air near the end of the tank and caused many engines to surge and cut on and off, you can fix this by blocking off that area and using only 1 or 2 holes close to the fuel feed (spray bar), this would stop the surging caused by the air bubbles. You could then jb weld or turn a 3/4 moon shaped piece to fill the ditch in the ST venturie.
The st venturie was better after this mod, you could use 2 holes if wanted in this configuration and you could also just use a smaller slit to connect the 2 feed holes, if you wanted to use 2, if this was used it is best to center the 2 holes between the sprat bar feed hole.
We made many adjustable venturies with 3 and 4 feedholes similar to the sprinkler one, but they were differant because they had a much smaller area inside to feed the holes with fuel. These worked OK but did not work better than a standard true venturie.
