  • June 24, 2025, 02:17:24 PM
Author Topic: ST 51 single hole spray bar set up  (Read 740 times)
Offline Ronald Eshleman
« on: June 20, 2012, 06:55:59 PM »
Where should the hole in the "single hole" ST 51 spray bar be pointed  I'm thinking "down" in the same angle as the venturi?  And what is a good needle setting to get started?  I'm thinking 3 and half turns out?
Re: ST 51 single hole spray bar set up
« Reply #1 on: June 20, 2012, 07:23:28 PM »
If anything, point the hole slightly to the rear from straight down.  I started with 4 turns out, it's easy to turn it in once it starts. ;D
BIG Bear
RNMM/AMM
Offline Chris Wilson
« Reply #2 on: June 20, 2012, 08:04:59 PM »
Its been lab tested and proven that the most suction is available at about 15º below the horizon but that places the jet in a critical position so rotate the jet just out of sight.
MAAA AUS 73427
steven yampolsky
« Reply #3 on: June 22, 2012, 03:28:46 PM »
I have been told that the location of the hole can be used to adjust amount of surge during the 4-2 break on a side mount configuration. Clockwise increases amount of surge for the insides and counter clockwise for the outsides. Just like the tank is used to  regulate the engine speed level vs. inverted, so does the position of the hole regulate how hard the engine surges on insides vs. outsides.
I've always put the hole pointing directly down along the center-line of the venturi and have not had an opportunity to test above theory. ;D
