  • July 14, 2025, 01:45:33 PM
Author Topic: O S L A 46  (Read 4691 times)
Offline Bootlegger
O S L A 46
« on: December 07, 2015, 11:45:22 AM »
  What is the stock head shim thickness for this engine?  Thanks...
8th Air Force Veteran
Gil Causey
AMA# 6964
Re: O S L A 46
« Reply #1 on: December 07, 2015, 12:39:38 PM »
Just perfect for a stunt run, AFAIK.
Re: O S L A 46
« Reply #2 on: December 07, 2015, 12:50:36 PM »
while this is most decidedly true Tim,,
you should take care ,, soon you will be lumped into the same basket with me ( that being smart a$$) ,,
then next thing you know they will lump all us NW guys into that basket,,
and while its likely true to a great extent,, i would rather make them meet us to figure it out ( see attendance at the regionals jump until the figure out who we really are)
All that said,, I am a bit perplexed by this question,, if you are running an LA 46, take the head off and measure it?
if you are not running one, uh,, ??
I guess perhaps if you have one that you suspect has been modified this might be relevant ,,
I am not home, and like Tim, I have no undying need to pull the head off one of mine so sorry,, I cant help,,
but I thought Tim's comment warranted a witty reply,, sorry to clutter upyour thread,,
Re: O S L A 46
« Reply #3 on: December 07, 2015, 01:35:04 PM »
Re: O S L A 46
« Reply #4 on: December 07, 2015, 01:51:19 PM »
Offline Bootlegger
Re: O S L A 46
« Reply #5 on: December 08, 2015, 07:32:21 AM »
   Well, the reason for the question is the fact that all of the la 46 engines that I have the shims have been changed and I don't have any way of knowing what the stock one was.
  But I say thank you Joe, I 'ppreciate the answer...
Gil Causey
AMA# 6964
Offline Chris Wilson
Re: O S L A 46
« Reply #6 on: December 08, 2015, 04:27:41 PM »
Begs the question as to why the shims were changed, and indeed what else was done along with it?
But the answer (minus the painfully circuitousness route) is 0.3mm.
MAAA AUS 73427
Re: O S L A 46
« Reply #7 on: December 08, 2015, 04:40:18 PM »
Sorry for the smart-ass answer, then.  I thought you were fixin' to murder an engine or two.
If they're shimmed and you don't know their provenance then Chris has a good point -- you may want to inspect them for timing mods, or inquire of former owners.
Re: O S L A 46
« Reply #8 on: December 08, 2015, 06:13:16 PM »
its all your fault Tim,,
If YOU hadnt been a smarty pants, I would have kept my fingers off the keyboard LOL, so there
Re: O S L A 46
« Reply #9 on: December 08, 2015, 07:14:47 PM »
Yes, we all know that you're totally incapable of being a smart-ass unless someone prods you.
Re: O S L A 46
« Reply #10 on: December 08, 2015, 07:18:46 PM »
well yeah
Re: O S L A 46
« Reply #11 on: December 08, 2015, 10:10:32 PM »
http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXCM65#tech
  Unfortunately, that does not seem to be correct. I just measured two of mine, brand new out of the box, and they are 0.4mm/0.016". That's enough different from 0.013 as asserted in the link that it will probably make a small difference in the way it runs, but it's probably not critical.
Re: O S L A 46
« Reply #12 on: December 09, 2015, 12:48:21 AM »
Wonder if all the deck heights are going to be within that production tolerance Brett?
MAAA AUS 73427
Re: O S L A 46
« Reply #13 on: December 09, 2015, 01:04:34 AM »
 One would certainly hope so!
