Engine basics => Engine set up tips => Topic started by: Bootlegger on December 07, 2015, 11:45:22 AM
Title: O S L A 46
Post by: Bootlegger on December 07, 2015, 11:45:22 AM
  What is the stock head shim thickness for this engine?  Thanks...
Title: Re: O S L A 46
Post by: Tim Wescott on December 07, 2015, 12:39:38 PM
Just perfect for a stunt run, AFAIK.
Post by: Mark Scarborough on December 07, 2015, 12:50:36 PM
while this is most decidedly true Tim,,
you should take care ,, soon you will be lumped into the same basket with me ( that being smart a$$) ,,
then next thing you know they will lump all us NW guys into that basket,,
and while its likely true to a great extent,, i would rather make them meet us to figure it out ( see attendance at the regionals jump until the figure out who we really are)
All that said,, I am a bit perplexed by this question,, if you are running an LA 46, take the head off and measure it?
if you are not running one, uh,, ??
I guess perhaps if you have one that you suspect has been modified this might be relevant ,,
I am not home, and like Tim, I have no undying need to pull the head off one of mine so sorry,, I cant help,,
but I thought Tim's comment warranted a witty reply,, sorry to clutter upyour thread,,
Post by: Joe Yau on December 07, 2015, 01:35:04 PM
http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXCM65#tech
Post by: Mark Scarborough on December 07, 2015, 01:51:19 PM
oh sure Joe,, take all the fun out of it with facts,, pfffttt  LL~
Post by: Bootlegger on December 08, 2015, 07:32:21 AM
   Well, the reason for the question is the fact that all of the la 46 engines that I have the shims have been changed and I don't have any way of knowing what the stock one was.
  But I say thank you Joe, I 'ppreciate the answer...
Post by: Chris Wilson on December 08, 2015, 04:27:41 PM
Begs the question as to why the shims were changed, and indeed what else was done along with it?
But the answer (minus the painfully circuitousness route) is 0.3mm.
Post by: Tim Wescott on December 08, 2015, 04:40:18 PM
Sorry for the smart-ass answer, then.  I thought you were fixin' to murder an engine or two.
If they're shimmed and you don't know their provenance then Chris has a good point -- you may want to inspect them for timing mods, or inquire of former owners.
Post by: Mark Scarborough on December 08, 2015, 06:13:16 PM
its all your fault Tim,,
If YOU hadnt been a smarty pants, I would have kept my fingers off the keyboard LOL, so there
Post by: Tim Wescott on December 08, 2015, 07:14:47 PM
Yes, we all know that you're totally incapable of being a smart-ass unless someone prods you.
Post by: Mark Scarborough on December 08, 2015, 07:18:46 PM
well yeah
Post by: Brett Buck on December 08, 2015, 10:10:32 PM
  Unfortunately, that does not seem to be correct. I just measured two of mine, brand new out of the box, and they are 0.4mm/0.016". That's enough different from 0.013 as asserted in the link that it will probably make a small difference in the way it runs, but it's probably not critical.
Post by: Chris Wilson on December 09, 2015, 12:48:21 AM
Wonder if all the deck heights are going to be within that production tolerance Brett?
Post by: Brett Buck on December 09, 2015, 01:04:34 AM
 One would certainly hope so!
