  • July 22, 2025, 04:14:16 PM
Author Topic: Blank  (Read 2948 times)
Offline Rusty
Blank
« on: April 23, 2016, 07:10:13 PM »
Blank
« Last Edit: March 11, 2022, 07:25:15 PM by Air Master »
Re: Needle Valve Questions
« Reply #1 on: April 23, 2016, 09:56:00 PM »
Sounds like a PA nva made by Nelson, Randy Smith from Aero Products might be able to help.
« Reply #2 on: April 24, 2016, 07:25:23 AM »
Rusty you might check Mecoa for K&B parts.  They own the franchise and can likely get you a replacement NVA.
« Reply #3 on: April 24, 2016, 11:25:35 AM »
Hello,
I was wondering where I could get a needle valve assy for a K&B Torpedo 35 green head?
I have some modern needle valve assemblies (unknown who made them) that have a white nylon compression cone to hold the setting.  It is compressed by a nut similar to a supertiger.   Where can I get some of these nylon cones?
can you post a picture of what you have?
« Reply #4 on: April 24, 2016, 06:09:32 PM »
The bottom one is mine,  have the  needles, lock collets, delrin seals, and nuts for that bar
I have standard size ones complete, what you have on the Stainless steel one is a PA one for a FOX 35
« Reply #5 on: April 24, 2016, 06:16:13 PM »
10-32 nut.
« Reply #6 on: April 25, 2016, 07:11:36 AM »
Thanks Guys.
Randy, how do I order some parts for them?
678 407 9376   or  email  randyaero@msn.com
« Reply #7 on: April 26, 2016, 09:46:58 AM »
That other nva has a split body. You tighten the cap down to set the drag and it seals on the threads like a SuperTiger nva. The inside of the cap should have a conical shape to squeeze the split line closed. I don't think it uses a nylon insert.
Offline bob whitney
« Reply #8 on: April 26, 2016, 10:06:56 AM »
 Rusty, i have some green head 35 needle valve assbly's   Rad Racer
rad racer
