  • June 19, 2025, 04:46:30 PM
Author Topic: What is the best way to remove and replace piston rings?  (Read 2657 times)
Offline frank mccune
« on: April 25, 2016, 05:59:12 PM »
      Hello All:
      Kindly give me some advice as to how one may do this without damaging the ring.
        Tia,
        Frank McCune
Re: What is the best way to remove and replace piston rings?
« Reply #1 on: April 25, 2016, 06:10:31 PM »
Call Frank Bowman's Rings Phone Number 505 327 0696. He is a vendor or rings for all brands of rings.
Best,     DennisT
Offline Terry Caron
« Reply #2 on: April 25, 2016, 06:57:07 PM »
I've had occasion only once to r&r rings, on a K&B .35, Frank, but had success by pressing the ring into the groove opposite the gap, which causes the ring ends to protrude slightly.
I then used the tip of a scribe to gently (spread if necessary) pry and lift the end of the ring just enough to let it rest on the piston above the groove.
At this point, gently lift the ring out of the groove a bit at a time, working your way around the piston.
Once it's out of the groove it should slide off the piston easily.
A lower ring can be treated similarly, except it may be better to work it down the piston skirt rather than try to work it over an upper groove.
With the ring setting on top of the piston, downward thumb pressure on it at one side of the gap will start the ring over the edge of the piston. With the other thumb gently work your way around, 'til it's possible to slide it down into the groove.
If you plan to reuse the rings, and if they're identical (I don't know - maybe some aren't), note which came from where as the upper may be more worn, so that installing the lower in it's place may give better compression.
Also note that some pistons have locating pins in the grooves to prevent ring rotation - doesn't affect removal so much but it's best to start replacement with the gap directly over the pin location so spinning the ring into position (with possible scoring) isn't necessary.
Best of luck with it.
Terry
NACA member, Huntsville, AL
AMA 249824
NRA Life Member
« Reply #3 on: April 26, 2016, 05:59:59 AM »
     Hi Terry and Dennis:
     Thanks for the replies.  Mr. Bowman has retired and I did not want to disturb his time away from the ring business thus is the reason for me to refrain from calling him.
      Dennis, your method is the same method that I learned to r&r rings in the past. I aint a very smart or clever person, I thought that I may receive additional tips.  I sure would hate to break  new ring!
        Thanks for the tips,
        Frank McCune
« Reply #4 on: April 26, 2016, 09:19:01 AM »
Gingerly .  S?P
and not when youve got the shakes , or hypothermia .
Offline Fredvon4
  • Central Texas
« Reply #5 on: April 26, 2016, 10:40:25 AM »
I am astounded at some of these answers but admit up front I have never removed or replaced a ring on a very small piston
I have on the other hand rebuilt and hopped up way too many car engines to number
the ONLY rings spiral removed or installed were the oil control ring(s) and spacer...ALL other rings were removed or installed with the proper tool....period
If I had a ringed small engine,  I would simply push the back side so each gap end was exposed outside the groove, and use a small set (I have) of expanding jaw snap ring pliers.... holding the back of the ring (opposite side of gap) to keep the ring in plane with the gap spread, and lift off NEVER touching the piston and install same way
ON full sized car engine rings, the tool spreads the gap open and grasps the ring top and bottom holding it stable...you ONLY open enough to ensure the HARD and Sharp ring Never touches and scores the much softer piston
again before all the shade tree mechanics start yammering about how they re ring by spiral scuff n slide on their engines----
The OP has another thread about rings not seating, fit, liner concentrically round, low compression etc etc
I suspect technique of removing and installing my be inducing a out of plane twist ...in other word once torqued UP or Down ...one gap end vs the other gap end..the ring will NOW NOT lay level 360 flat on a .0001 granite surface
with ductile iron, opening the gap on level plane you do two good things... it never springs back to the same gap slightly increasing the outward spring tension. And there is no induced twist forcing the ring to ride high in the groove for some part of the circumference and low in other spots
I admit another don't know (don't really care cuz I have zero ringed glow engines)....is there a definable top and bottom as is common on MOST automotive rings
Below the snap ring could be modified to be flat faced instead of round pins for spreading
The other is perfect already a Lilly tool and NOT expensive
« Last Edit: April 26, 2016, 11:06:03 AM by Fredvon4 »
Fred von Gortler IV
Offline Terry Caron
« Reply #6 on: April 26, 2016, 11:25:48 AM »
Hi Fred -
I'm not familiar with the snap ring pliers you mention - could you post a pic of them, please?
Thanks.
Terry
AMA 249824
NRA Life Member
Offline Fredvon4
  • Central Texas
« Reply #7 on: April 26, 2016, 12:48:02 PM »
Lisle snap ring pliers
Any guess at what third photo tool is?
Fred von Gortler IV
Offline Jim Dincau
« Reply #8 on: April 26, 2016, 12:52:43 PM »
Piston ring groove scraper
Unless it's crazy, ambitious and delusional, it's not worth our time.
Offline Fredvon4
  • Central Texas
« Reply #9 on: April 26, 2016, 01:08:08 PM »
yes sir and a very old one from the late 40s my dad used rebuilding cars and farm equipment as a young man
Fred von Gortler IV
Offline Terry Caron
« Reply #10 on: April 26, 2016, 01:12:44 PM »
Are those pliers small enough to remove, say, a .750-.800" ring, Fred?
Terry
AMA 249824
NRA Life Member
