Engine basics => Engine set up tips => Topic started by: Rusty on April 23, 2016, 07:10:13 PM
Title: Blank
Post by: Rusty on April 23, 2016, 07:10:13 PM
Blank
Title: Re: Needle Valve Questions
Post by: Motorman on April 23, 2016, 09:56:00 PM
Sounds like a PA nva made by Nelson, Randy Smith from Aero Products might be able to help.
MM
Post by: Dave_Trible on April 24, 2016, 07:25:23 AM
Rusty you might check Mecoa for K&B parts.  They own the franchise and can likely get you a replacement NVA.
Post by: RandySmith on April 24, 2016, 11:25:35 AM
Hello,
I was wondering where I could get a needle valve assy for a K&B Torpedo 35 green head?
I have some modern needle valve assemblies (unknown who made them) that have a white nylon compression cone to hold the setting.  It is compressed by a nut similar to a supertiger.   Where can I get some of these nylon cones?
can you post a picture of what you have?
Post by: RandySmith on April 24, 2016, 06:09:32 PM
The bottom one is mine,  have the  needles, lock collets, delrin seals, and nuts for that bar
I have standard size ones complete, what you have on the Stainless steel one is a PA one for a FOX 35
Post by: Motorman on April 24, 2016, 06:16:13 PM
10-32 nut.
Post by: RandySmith on April 25, 2016, 07:11:36 AM
Thanks Guys.
Randy, how do I order some parts for them?
678 407 9376   or  email  randyaero@msn.com
Post by: Motorman on April 26, 2016, 09:46:58 AM
That other nva has a split body. You tighten the cap down to set the drag and it seals on the threads like a SuperTiger nva. The inside of the cap should have a conical shape to squeeze the split line closed. I don't think it uses a nylon insert.
MM
Post by: bob whitney on April 26, 2016, 10:06:56 AM
 Rusty, i have some green head 35 needle valve assbly's   Rad Racer
