  • July 15, 2025, 02:33:05 AM
Author Topic: Mounting Bolt Pattern of Fox .36 plain bearing engine  (Read 1003 times)
Offline David Ruff
« on: April 02, 2018, 09:15:33 PM »
Anybody know if any other engine  has the same mounting bolt pattern as the Fox .36 plain bearing slant plug engine.
I need an engine that weighs about two more ounces.
Retired Army
Offline C.T. Schaefer
Re: Mounting Bolt Pattern of Fox .36 plain bearing engine
« Reply #1 on: April 03, 2018, 05:45:54 AM »
G-21  .35?
Offline Jim Mynes
  • Chelsea, ME
« Reply #2 on: April 03, 2018, 03:35:26 PM »
I know the Fox .29 of the same era is virtually identical. Given the smaller bore, it should be heavier.
But, I’d wager this is not the answer you’re looking for.
I had a .29 on a Banshee back in my teens, as I recall it was fairly gutless.
I have seen the light, and it’s powered by a lipo.
Offline Bob Matiska
« Reply #3 on: April 03, 2018, 04:29:16 PM »
Dave, I measured the hole pattern of my 29 engine and my 36 crankcase at 1.625 by 0.625 inch (or 1 & 5/8 by 5/8 inches).  The Fox 29X and 36X needle bearing engines I have measure the same.  The Fox Combat Special Mk II (?) of mid-1970s vintage I have also measures the same. I'm not sure what current engines would fit.  Someone here sells Enya's, I think, so you might see if they measure up.  Do you need more power or more weight, or both?
Bob in NEPA
AMA 56267
Offline David Ruff
« Reply #4 on: April 03, 2018, 06:21:55 PM »
More weight. I opted for the two ounce Higley heavy hub.
Retired Army
