  • July 14, 2025, 06:02:47 PM
Author Topic: Issues with a BRAND NEW Orwick 29.  (Read 1077 times)
Offline Robert Zambelli
« on: March 29, 2018, 11:32:08 PM »
At this point, my Shaper is just about finished. It will be powered by a brand-new Orwick 29 on spark ignition.
A couple of days ago, I decided to run the engine in on the stand. Going through the usual drill, I mounted a 10-6 wood prop and set the engine up on the stand, complete with my trusty ignition box (anyone interested and I’ll write about it).
After around a half hour of flipping, I finally got it started.
In a word, PATHETIC.  ??? It made so little power and ran so rough, I doubt that it would have taxied the plane. Tried the usual – different plug, different fuel, even a different prop. Still pathetic.   HB~> Since Orwicks had a reputation for being powerful engines, something was definitely wrong.
Next try, pull the head and see what’s going on inside. Looked at the head.
First surprise – no combustion chamber.  ~^  The bottom of the head was flat, as seen in figure 1. The spark plug was recessed around ¼ inch above the flat.
Second surprise – the sleeve was rotated 180 degrees. On the downstroke, the intake port was opening around 1/32 of an inch before the exhaust port.
I modified the head as shown in figure 2, rotated the sleeve to properly orient the ports, removed the thick fiber head gasket and installed a thin aluminum gasket and reassembled.
Starting it now was a snap and the engine came alive.   #^  #^ Turned the 10-6 wood prop at just under 11,000 RPM. The fuel was regular gasoline with 18% castor, 6% synthetic.
Except for my ETA 29, this is the most powerful 29 I’ve ever run.
Offline GERALD WIMMER
    • Auckland Free Flight Club
Re: Issues with a BRAND NEW Orwick 29.
« Reply #1 on: March 30, 2018, 04:40:23 AM »
Hello Bob
Nice to hear you got a good running engine in the end but how come it was so badly assembled to begin with? Do you suppose someone assembled it from parts or did the Orwick factory have very poor quality control? No combustion chamber sounds like a diesel conversion  :-\  ???
Interested to know more about your mysterious 'ignition box' of tricks which I presume it has a transistor or two and more then a 3 volt source  ;)
11 grand on a 10x6 is better then some much newer 35's and would probably beat some of my old Enya 6001 45's  :-[
Regards Gerald  #^
« Reply #2 on: April 03, 2018, 05:35:04 PM »
I'm running two Orwick 29 engines ( made by Henry Orwick, after 1950)  One on spark ignition and one on glo.  Both are very strong, and certainly equal to any modern 29.  Just remember to use lots of oil, about 25%.
