  • June 19, 2025, 06:27:31 PM
Author Topic: Motor/header gasket question for Randy  (Read 1021 times)
Online James Mills
« on: August 22, 2007, 08:49:39 PM »
Randy,
Do I need a gasket between the motor and header on the PA 61 pipe set up (hope this isn't a question that makes you start hitting your head on the wall)?
James
AMA 491167
Re: Motor/header gasket question for Randy
« Reply #1 on: August 22, 2007, 09:51:33 PM »
Randy,
James
[/quote
Hi James
Many people do not use any gaskets with good results, the surfaces have extremely smooth surfaces so they can get away with it.  That said what I use, and what I recommend is to use metal duct tape, this is very thin aluminum type tape that has a paper backing and is sticky on one side, It is very very easy to just stick a piece on the header, trimmimg it out with an Exacto and bolting it up to the motor.
Others use a very thin coating of any of the colored silicone sealant. Hope this helps
Online James Mills
« Reply #2 on: August 22, 2007, 09:56:22 PM »
Randy,
James
[/quote
Hi James
Randy,
Where do I get the metal duct tape?
James
AMA 491167
« Reply #3 on: August 22, 2007, 10:33:47 PM »
Hi James
You can get tape at any aircondition/heating supply store, and  maybe  ACE hardware, or Home depot
Offline Bradley Walker
    • The Urban Rifleman
« Reply #4 on: August 24, 2007, 07:03:25 AM »
Hi James
It is also used for auto body work.  Look near the Bondo at the auto store.
-George Bernard Shaw
