Agree with all! It's also quite a bargain, especially used.
The LA .15 is a fine little sport engine. I bought mine as an RC version, made a quick venturi and was in business.
Mine had a rather bulky baffled muffler. I removed the baffle, shortened and lightened it and it works perfectly.
I run a 7-6 Master Airscrew and Brodak 10/23 fuel. Single vent tank, no uniflow, no muffler pressure.
Set is lean on the ground and let it scream through the flight.
