Engine basics => Engine set up tips => Topic started by: James Mills on August 22, 2007, 08:49:39 PM
Randy,
Do I need a gasket between the motor and header on the PA 61 pipe set up (hope this isn't a question that makes you start hitting your head on the wall)?
James
Randy,
James
[/quote
Hi James
Many people do not use any gaskets with good results, the surfaces have extremely smooth surfaces so they can get away with it. That said what I use, and what I recommend is to use metal duct tape, this is very thin aluminum type tape that has a paper backing and is sticky on one side, It is very very easy to just stick a piece on the header, trimmimg it out with an Exacto and bolting it up to the motor.
Others use a very thin coating of any of the colored silicone sealant. Hope this helps
Regards
Randy,
James
[/quote
Hi James
Regards
Randy,
Where do I get the metal duct tape?
James
Hi James
You can get tape at any aircondition/heating supply store, and maybe ACE hardware, or Home depot
Regards
Hi James
Regards
It is also used for auto body work. Look near the Bondo at the auto store.
