  • June 20, 2025, 05:56:53 PM
Author Topic: Looking for OS MAX-S 30 RC  (Read 1450 times)
Offline Jim Treace
  • 1979 600 Aerostar N79JT
« on: July 30, 2009, 05:02:18 PM »
Anyone know where I can get an OS MAX-S .30 RC ? I have one and converted it to C/L and now need another. I Tried Ebay but all I can find are .35's. My new build has engine mounts, cowling all completed to fit the .30 and then I went and damaged it. 3/32" drill slipped and punched a hole in the casing. Don't think it can be repaired.
Jim
Jim Treace
Ponte Vedra Beach, FL &
Paris, TN
AMA 855251 "Too soon we grow old...Too late we grow wise"
Offline John Miller
Re: Looking for OS MAX-S 30 RC
« Reply #1 on: July 30, 2009, 05:09:11 PM »
I b elieve the .35 and .30 share the same case.
« Reply #2 on: July 30, 2009, 06:33:10 PM »
Jim
I may have a new one, or could build a new 30 S
Offline Jim Treace
« Reply #3 on: July 30, 2009, 06:42:25 PM »
Randy,
I'll drop you a pm about the new one (or built up if necessary).
Jim
Jim Treace
Paris, TN
Offline James C. Johnson
« Reply #4 on: July 31, 2009, 10:12:06 AM »
I think I have one used one left..  would let it go .. can post pics if you are interested..
Jim
« Reply #5 on: July 31, 2009, 01:58:43 PM »
Randy,
Jim
Hi Jim
I did have a new one plus many parts
see your PM
Also i maybe able to repair you old one
Offline W.D. Roland
« Reply #6 on: August 13, 2009, 12:31:18 PM »
The .30 and .35 are the same except bore.
The heads do not interchange.
I have some new piston/sleeves and some other parts.
David
51336
David Roland
51336
« Reply #7 on: August 13, 2009, 12:57:50 PM »
Wait a minute!  A small hole in the crankcase is easily repaired with JB Weld.  Pressures are very small, so it should hold forever, if the part is thoroughly cleaned before the JB Weld.
I could list dozens of similar repairs I've done with JB Weld, and all were successful.
« Reply #8 on: August 13, 2009, 01:55:19 PM »
If It is in a place that would let you, the best thing is to tap it with a 4-40  6-32 whatever and screw in a set screw with either RED locktite  or JB weld
Offline W.D. Roland
« Reply #9 on: August 13, 2009, 06:36:34 PM »
A local flier JB welded a Johnson .35 combat cylinder back on the crankcase, actually the upper and lower crankcase back together and ran it for years like that.
David
51336
David Roland
51336
Offline Jim Treace
« Reply #10 on: August 13, 2009, 07:36:20 PM »
Yup, I already did this. Cleaned carefully, then cleaned again. Tap for 4-40 screw w/JB Weld. Holds fine and engine runs like it didn't know what happened. I had to surface grind down 4-40 head so I could fit the cowling bolt. Not much space under the engine mounts with the engine in place.
However, Randy, I will use the new one from you and keep my repaired tapped one as a back up or on my next project.
Jim
Jim Treace
Paris, TN
Offline Jerry Reider
« Reply #11 on: November 20, 2009, 02:56:27 AM »
Jim
There's an O.S. Max-s .30 R/C Engine, No Muffler on Ebay right now.  Search for O.S. Max 30 and you'll find it.  Looks pretty nice.  Hurry only 2 days left on the sale.  I just bought a really nice O.S. Max .35 R/c off Ebay.  Great deal.  Very little wear ,clean and well taken care of.  I have 2 other 35 Max-s's that just keep on running strong.
Jerry
