  • June 25, 2025, 04:04:06 PM
Author Topic: Howz about...  (Read 992 times)
Offline Bootlegger
Howz about...
« on: September 14, 2012, 11:15:30 AM »
 ::)   The size of the venturi in an O S L A 10, also what needle assy do y'all recommend?
        Thanks y'all               y1
8th Air Force Veteran
Gil Causey
AMA# 6964
Re: Howz about...
« Reply #1 on: September 14, 2012, 11:17:57 AM »
Brother Gil,
Jim Lee: FP or LA
BIG Bear
RNMM/AMM
Offline Bootlegger
Re: Howz about...
« Reply #2 on: September 14, 2012, 11:21:07 AM »
  Thank ya' Bill will he have both parts?  Again thnaks
Gil Causey
AMA# 6964
Re: Howz about...
« Reply #3 on: September 14, 2012, 11:45:13 AM »
Hi Gil,
Like I have stated before the "original" NVA for the FP is basically unobtainable now.  I never saw the LA in C/L form.  If OS made a C/L version of the LA then the NVA should work on both.
I have FP and FSR .10s.  They use the same NVA.   I have found a few NVA over the past few years.  Unfortunately the ones I have are in or slated for models.
And again, the "old" .10S venturi and NVA will not work.
BIG Bear
RNMM/AMM
Offline kenneth cook
Re: Howz about...
« Reply #4 on: September 14, 2012, 03:53:30 PM »
             I do have a FP.10 but I never ran it. It's been said to me that these needles are unobtainable. Why doesn't the Max-S needle and spraybar fit. Is the diameter too large? Is it too small? Why doesn't the FP, LA .15 needle fit. I don't know the answers here so I'm inquiring as well. If too large, could the larger be turned down? Ken
Re: Howz about...
« Reply #5 on: September 16, 2012, 01:37:39 PM »
HI Kenneth,
The .10"S" venturi and NVA are both too small to use in the FP.
BIG Bear
RNMM/AMM
