  • June 25, 2025, 10:41:09 AM
Author Topic: ?? suggestions...  (Read 716 times)
Offline Bootlegger
?? suggestions...
« on: September 14, 2012, 03:26:19 PM »
   ::)  Any one have any suggestions as to what needle and spray bar will fit an OS LA 10 engine?
        Thanks,     #^
8th Air Force Veteran
Gil Causey
AMA# 6964
Offline don Burke
Re: ?? suggestions...
« Reply #1 on: September 14, 2012, 09:57:21 PM »
        Thanks,     #^
If you have access to a lathe, you might be able to turn down one for an OS15 or 25.  Then use nylon spacer blocks to center the spray bar holes in the venturi.
don Burke AMA 843
Menifee, CA
Offline Bootlegger
« Reply #2 on: September 15, 2012, 01:40:48 PM »
 y1   Thank ya' Don, I'll give that a try...
Gil Causey
AMA# 6964
« Reply #3 on: September 15, 2012, 01:59:25 PM »
If you can't fit the threaded part of the spraybar in the crank case holes then you're already shot out of the water, unless you want to hack up your crank case.  But if you have a spraybar where the threaded portion will fit but not the smooth portion, it should be reasonable to turn it down.
Offline Geoff Goodworth
« Reply #4 on: September 15, 2012, 05:46:23 PM »
The carb retaining screw in the parts list is M3 so the NVA from the 15 should fit.
