  • June 18, 2025, 04:38:33 AM
Author Topic: Wristpin pads for McCoy 40  (Read 799 times)
« on: October 04, 2007, 02:01:54 PM »
Does anyone make the teflon end pads for McCoy 40 R/H wristpins? I think these were only used on some of the later ones. I have an earlier one that has brass eyelets.
Offline Marvin Denny
Re: Wristpin pads for McCoy 40
« Reply #1 on: October 04, 2007, 05:07:00 PM »
Scott Riese.  I believe he is out of commission at the present time.  Do you need some?  I have a couple of extras.
  Bigiron
marvin Denny  AMA  499
« Reply #2 on: October 04, 2007, 06:21:39 PM »
I need 1 Marvin. I did a dumb thing and lapped the piston in with the pads in the pin. I use the wristpin in my fixture ( clothespin )  and lapped the end right off that little bugger. The other one is fine. Live and learn.
Offline Tom Dugan
« Reply #3 on: October 05, 2007, 09:27:02 AM »
I have purchased teflon pads alone from MECOA for my K&B 61.  I was just at their website and see that they list a part number for the pads alone pn: 26-4001.  You might give them a try to see if what they have will adapt  WWW.MECOA.COM in parts department, go to the exploded views, or you can call them directly.
Tom
« Reply #4 on: October 05, 2007, 01:51:30 PM »
Thanks Tom; I had forgotten about MECOA. They might have the ones for the McCoy also, as I believe they have the latest Testors McCoy engines. Thanks again for the reminder.
