  • June 20, 2025, 03:00:02 PM
Author Topic: LA.25  (Read 1758 times)
Offline mark eisenhut
    • madphotos.net
LA.25
« on: November 07, 2006, 09:20:05 PM »
is there a way to get rid of the plastic backcover plate with the remote needle valve and go with a regular set up?
thank you
mark
mark eisenhut
Offline Tom Perry
Re: LA.25
« Reply #1 on: November 07, 2006, 09:55:16 PM »
You can replace the nozzel in the venturi with a NVA and just bypass the remote needle valve or remove it completely.  If you keep the plastic backplate I would advise not clipping the needle valve holder off.  Just remove the needle to keep future options open.  You can replace the backplate with a metal one from an FP 25 or a couple of othe FP clones that the names of the motors escape me right now.
 AP^
Tight lines,
Tom Perry
 Norfolk, Virginia
Offline Leester
Re: LA.25
« Reply #2 on: November 08, 2006, 01:43:28 AM »
Tower has the cover plate part # 22307000
Leester
ama 830538
    • madphotos.net
Re: LA.25
« Reply #3 on: November 08, 2006, 05:38:57 AM »
do i need the screw kit also or are screws i have ok ? or just gasket kit and st needle valve assembly to be set ?
thanks for all your help mark
mark eisenhut
Offline James Lee
Re: LA.25
« Reply #4 on: November 08, 2006, 07:20:37 AM »
Mark
The existing screws will be OK...   I would suggest the FP metal backplate and conventional NVA assembly from the FP...   Tower should have the backplate and nva...   the ST nva will work fine but will require a larger venturi opening.  the OS nva is app .136-.140 dia while the st is .156...
Jim
    • madphotos.net
Re: LA.25
« Reply #5 on: November 08, 2006, 07:31:42 AM »
thanks for the info its what i wanted to here.
thanks again
mark
mark eisenhut
Offline Ken Deboy
    • Silk and Dope
Re: LA.25
« Reply #6 on: November 08, 2006, 09:26:03 AM »
Tower part numbers:
Gasket Set LXCM49
Cover Plate LXCF89
Venturi LXCW99
NVA LXCR49
I have these on an LA25 and it runs great, stock 2030 muffler, Brodak 2-1/2 wedge tank with muffler pressure.
cheers,
There is a fine line between "hobby" and "mental illness"
Offline Leester
Re: LA.25
« Reply #7 on: November 08, 2006, 09:49:01 AM »
There is nothing wrong with the screws that come with it but the socket head screws eliminate stripping the head slot and aren't that much money.
Leester
ama 830538
Offline Tom Perry
Re: LA.25
« Reply #8 on: November 08, 2006, 10:26:43 AM »
Lee,
Did you get a chance to convert the LA .25 you won in the drawing yet?  I hope thse were the right parts I sent.
 AP^
Tight lines,
Tom Perry
 Norfolk, Virginia
Offline Leester
Re: LA.25
« Reply #9 on: November 08, 2006, 07:55:29 PM »
All parts are the correct ones, you did good. These are great engines very user friendly.
Leester
ama 830538
