  • June 25, 2025, 05:34:47 AM
Author Topic: Fuel filter options  (Read 1614 times)
Offline John Castle
  • The Bent Pin
Fuel filter options
« on: April 02, 2011, 07:38:23 PM »
It seems that Master Airscrew has discontinued their small fuel filters. :(  I know that they were not perfect but with a bit of heat shrink tubing they were light, small and cheap. I can't say that I am happy with any of the alternatives offered as they tend to be heavy, big and expensive.
Do any of you know of any alternatives that may be available?
John Castle
McMinnville, Oregon
AMA# 589650
Offline sleepy gomez
Re: Fuel filter options
« Reply #1 on: April 02, 2011, 08:42:26 PM »
When you find an alternative let me know.  I will buy 30 this time.
Offline ray copeland
« Reply #2 on: April 02, 2011, 09:01:42 PM »
I will be watching this thread with interest. I e-mailed Master Airscrew about 6 weeks ago and got a response that read, "i know what you are talking about, i believe we still have some in the warehouse and i will be back to you soon".  Nothing yet. I guess i will be using the Hayes filters at about $3.oo apiece. I may even spring for some of the small crap traps.
« Reply #3 on: April 03, 2011, 12:15:45 AM »
I use Crap Traps on the big planes and Dubro screw together ones on profiles and such.
Richard Oliver was selling some inline filters (screw together, "cleanable") that were barely larger than the silicone fuel line and maybe 5/8th" long.  I got a few but wish I could find out a new source for them.  ???
Big Bear
« Reply #4 on: April 03, 2011, 11:12:47 PM »
Big Bear
http://www.jettengineering.com/accy/filter.html
« Reply #5 on: April 03, 2011, 11:14:00 PM »
Thank you, Brett!  Those come in mighty handy in tight quarters.
(feeling DUMB!  should known to contact Dubby)
Offline Ward Van Duzer
« Reply #6 on: April 04, 2011, 07:39:00 AM »
The old H & R (Richie Blatt) screw together filters are now being carried by Brodak. Part # BH-935 @ $4.49.
TIP: Always make sure a screw together filter is tight before using it!
W.
Offline kenneth cook
« Reply #7 on: April 05, 2011, 02:19:55 PM »
          For those that use the H&R filters, I'm sure you've had the problems of cleaning them at the field. I've tried to blow the filter out and completely blown the screen out of the filter and into the grass. Don't panic, the Cox screen from the red fuel cans work terrifically. I've had several of them around and I believe the mesh may even be smaller than what was actually provided in the stock filter. I had several of these laying around with no screens. Its nice to know that they can be put to use again. Ken
« Reply #8 on: April 06, 2011, 10:21:29 AM »
True! BUT...When Richie had the company he also sold the little wire "clippies", and additonal screens! Try Brodak for extra screens!
FWIW, whenever I reverse flush any filter, (no I never try to blow one clean) I do it against a piece of white paper. that way you can see what you've cleared away. Especially if it's the filter screen!
W.
