  • June 25, 2025, 12:37:49 PM
Author Topic: HP40  (Read 1521 times)
Offline ash
HP40
« on: April 02, 2011, 03:45:25 AM »
I just picked up a near complete HP40 and one in need of some internal parts. They're both Austrian made and have bare aluminium cases, so presumably the Silver Star variant as opposed to the Black/Gold Gold Cup version.
Questions:
1. What's the difference between the Silver and Gold versions othr than the colour? I understand later GCs had a ringed ABC setup, whilst the SS were always steel/iron.
2. What can they be used for competitively? One is destined for a carrier model, what else can they do? Speed? Stunt?
3. Are the new Mecoa parts compatible with the old Austrian made engines?
Offline Andrew Tinsley
Re: HP40
« Reply #1 on: April 02, 2011, 08:40:40 AM »
I have a similar HP40, NIB, must have been fro the early 1980s. It doesn't seem to be too heavy and I often wondered if it would make a decent stunt engine.
Andrew.
BMFA Number 64862
Offline bill mazzoni
Re: HP40
« Reply #2 on: April 02, 2011, 10:42:34 AM »
HP-40's make a great stunt engine. I have several in stunt planes now. Have one in my SCIMATAR. Bob Hunt used HP-40's in some his stunt planes.
Most of the ones I have are with the steel liner's. The Silver and black & gold seem to be the same. I have one new Black & Gold that is ABC.
Tom Hampshire of the Circle Burners Club does reworks on the HP-40. He did several for me. Randy Smith has a Tongue Muffler for the HP-40.
You won't be disappointed !!!!
Bill Mazzoni
Offline dennis lipsett
Re: HP40
« Reply #3 on: April 02, 2011, 12:44:13 PM »
Most of the Silver Stars that I saw did not have a front ball bearing. Friend of mine had a Royal b-25 with 2 Silver Line HP's that were absolutely reliable for years on that airframe. Easy starting and flawless runs. I never owned one. But the gold Cups are really superb engines. They ran like a fine watch for me back in my R/C days.
Dennis
Re: HP40
« Reply #4 on: April 05, 2011, 04:03:15 AM »
Bill Wewage run one in a Piroque at the world champs. If thats how you pronounce it .
Use something more common for crasshing into carrier decks . mw~ D>K H^^ ;D
Re: HP40
« Reply #5 on: April 05, 2011, 10:32:30 AM »
All my HP-40's have Supertigre needle valves.  Works great with a 11X5 Rev-up or Zinger prop.
Bill Mazzoni
Offline ash
Re: HP40
« Reply #6 on: April 05, 2011, 03:38:08 PM »
Thanks for the comments, guys.
These ones definitely have a front bearing. And the removable front shaft housing.
The throttle has an OS needle on the HP NVA and a couple of different HP NVAs in a bag.
Both have cracks in the venturi/throttle stub from overtightening of the mounting screws. I think I might have to drill the holes out and do that the OS way to prevent further damage.
Unfortunately .40 is not a size I am inclined to use for stunt, although I must confess a Novi III with one of these would fit nicely in the long-term wish list.
Offline Chris Wilson
Re: HP40
« Reply #7 on: April 05, 2011, 07:37:08 PM »
Seems to be a common problem!
http://www.modelengine.org/forum/viewtopic.php?p=4705&sid=140cd49a87558a584cadfe30c0fa5622
MAAA AUS 73427
Offline ash
Re: HP40
« Reply #8 on: April 06, 2011, 12:32:36 AM »
Yep, both front housings have cracks in the same place, one of them on both sides. The casting is very thin there when it should be quite thick.
Offline ash
Re: HP40
« Reply #9 on: April 06, 2011, 01:02:56 AM »
I just discovered that the spare case has a long crack running under one mounting lug. That narrows it down to one good engine with a spare crank, head and rings. Still a bargain.
Offline Ward Van Duzer
Re: HP40
« Reply #10 on: April 06, 2011, 10:14:23 AM »
Based on my 7-8 years of working in Randy's shop I can say the these are (can be) excellent stunt engines. Extremely light weight, and when properly tuned, very strong. If you want one set up for you, I'd talk to Randy. The general problem with all of these is that they came in many varients, each requiring different "fixes". They kind of faded away because of parts issues and the appearance of the Magnum/Thunder Tiger .36 later converted into the Aero Tiger.
W.
