  • June 20, 2025, 04:21:06 PM
Author Topic: Muffler screws for a .25 FP  (Read 1020 times)
Offline John Castle
  • The Bent Pin
« on: March 04, 2010, 09:14:01 AM »
Does any body know what size the muffler screws are for an os .25 FP. I would like to replace the stock slotted ones with allen head screws. Any ideas on where to get the allen screws would be great.
John Castle
McMinnville, Oregon
AMA# 589650
Offline George Waters
Re: Muffler screws for a .25 FP
« Reply #1 on: March 04, 2010, 12:38:07 PM »
John   I just retapped the muffler for 4-40 threads and used regular allen head bolts.  Georg Waters
Offline Peter Hess
« Reply #2 on: March 04, 2010, 01:42:02 PM »
John:
I am not sure about muffler screws for the 25 FP but I do know that the muffler screws for the Enya 25 are M3 x 25.  I would not be terribly surprised if they were the same.  Take your muffler with you to your local hardware store and give one a try.  Also, my hobby shop has a good Dubro display of metric parts and I found M3 x 30s there.
« Last Edit: March 04, 2010, 02:49:45 PM by Peter Hess »
Peter Hess
Canton, CT
AMA 485070
ChrisSarnowski
« Reply #3 on: March 04, 2010, 06:01:50 PM »
Tower's web site says they are M3x27mm.  I use either 25mm or 30mm length, don't remember which. You should be able to get them at a well stocked hardware store.
-Chris
Offline John Castle
  • The Bent Pin
« Reply #4 on: March 04, 2010, 06:27:15 PM »
Thanks for the help. I guess it's time for a trip to the hardware store.
John Castle
McMinnville, Oregon
AMA# 589650
« Reply #5 on: March 05, 2010, 11:15:26 AM »
While you're at it, replace any other phillips, slotted or Japan standard fasteners with Allen head cap screws.  It won't get any easier when they sieze up.
