I have a Super Merlin with the red head. I peered into the venturi and couldn't see any holes in the spraybar. When running your engine, you will probably have to increase compression to get it to start. After it starts, back the compression off as it warms up. It should run steadily and speed up to a point, then start missing from being undercompressed. Compress it back a little, and fiddle gently with the needle. It should speed up to a point as you lean out the needle, then start missing again. Richen it up. Break it in a little undercompressed and a little rich. Generally the more you run a diesel the better it runs. Flying it control line, it should run smooth and steady in level flight. If it slows in maneuvers, it is overcompressed, If it misses in maneuvers, it is a hair lean. The exhaust, with a commercial fuel, should be honey colored to clear. The exhaust is fairly cool. I routinely stick my finger into diesel exhaust to see what color it is. if you do this with a glow engine,you will have a burned finger.
