  • July 18, 2025, 06:46:16 PM
Author Topic: spinners  (Read 746 times)
Offline frank j. scire
spinners
« on: May 08, 2012, 09:01:15 PM »
Hey guys, hope all is well. I'd like to put a spinner on my McCoy 19 red head. I saw Mecoa has parts to do this. I'm not sure about thread size or exactly what I need. Do I need one with cut outs for the prop,or can I just get it with a flat bottom. I'm doing this so I can use an elec. starter as well as astedics.
      I also want to put spinners on my cox .049 I see they have rubber as well as a metal set up. Will the rubber ones work ok with the elec. starter.
                                                      Thanx for any help
                                                              frank
         PS I'm gonna post in classifides for the parts I NEED.
Re: spinners
« Reply #1 on: May 08, 2012, 09:38:50 PM »
I cant help specifically with the spinner,, most any will do since crank threads are fairly standard within engine size ranges.
I will however STRONGLY reccomend that you resist using an electric starter on your red head McCoy. STRONGLY!!, it is a plain bushed engine, and I would suggest that an electric starter can cause the crank~ conrod interface will make unfriendly contact with the backplate with less than good results..
