  • June 16, 2025, 10:00:05 PM
Author Topic: O S 30 Stunt  (Read 1193 times)
Offline Bootlegger
O S 30 Stunt
« on: February 23, 2020, 04:55:22 PM »
  I am no sure where this should go so I'll start here, I have an O S 30 stunt engine that I need some allen socket screws for, but I don't know the thred or the pitch, where might I get them, also might need a couple of the gasket sets also, tanks a lot...
8th Air Force Veteran
Gil Causey
AMA# 6964
Offline Bill Hummel
Re: O S 30 Stunt
« Reply #1 on: February 23, 2020, 06:11:45 PM »
Hi Gil, I believe Jim Lee can help you with the socket head bolts .
ama 72090
Re: O S 30 Stunt
« Reply #2 on: February 23, 2020, 07:36:15 PM »
Theyve got a soft aluminum head gasket , burried up in the ' rebate ' . Tease out with a scalpel tip . Re Roll Flat with round thing afterward .
Lotta guys just use silicone High Temp, on backplates these days .
Put a ' Large ' of the three OS Max 20 intakes in a O S 30 , centuries ago . Theyre essentially a 35 - S . Half the bits interchange .
The H 29 - R unbelievably has the same piston / liner / rod / wrist pin . So your allowed to run it on 20 % Nitro & race props too .
Bolts are 2 1/2 or 3 m.m. metric . or suchlike,  same as 35 - S anyway .
Offline Walter Johnson
Re: O S 30 Stunt
« Reply #3 on: February 26, 2020, 11:26:58 AM »
The rear cover and head bolts are M3x0.6mm not a common size. Micro Fastners.com and Lee Machine has these available. As for gaskets give Randy Smith (Aero Products) a call he will be able to take care of those and maybe the bolts too. Yogi
Take a spin.....You might like it.
Offline Bootlegger
Re: O S 30 Stunt
« Reply #4 on: February 26, 2020, 01:19:26 PM »
   Guy's I sure do than you a lot, Randy Smith suggested tapping 4-40 and it worked great so here is an up F Y I ..Bootlegger
Gil Causey
AMA# 6964
Re: O S 30 Stunt
« Reply #5 on: February 26, 2020, 08:27:23 PM »
Hi Gil   I would not tap the holes  I would just  use the  4-40 bolts, they are close enough  that no tap is needed,  I also sent a email  with the  parts you wanted cost on
