  • June 15, 2025, 04:59:47 PM
Author Topic: Enya .19-V 4005 Setup?  (Read 2986 times)
Offline Adam Riehl
« on: February 27, 2020, 10:44:52 AM »
Does anyone have any information about the Enya .19-V? A manual, prop size, or specifications? Also what is the power compared to a Fox .15?
Online Robert Zambelli
Re: Enya .19-V 4005 Setup?
« Reply #1 on: February 27, 2020, 01:06:04 PM »
Hi, Adam - I have a number of Enya 19s  and once properly run in, they are great engines.
They do require quite a bit of run-in time.
WAY more powerful than a Fox 15.
As far as fuel, I run mine on 10% nitro, 22 or 23% oil, 50/50 castor/synthetic.
I've tried a number of different props. 8-6, 9-4, 9-6 and even a 10-4.
You really have to experiment to find out which prop size and brand works best for your aircraft.
I may have a manual - if so, I can scan it and e-mail it to you.
Offline Adam Riehl
« Reply #2 on: February 27, 2020, 01:31:44 PM »
Robert, thanks. If you have the manual, I would appreciate if you would send it to me.
Offline Brian Hampton
« Reply #3 on: February 27, 2020, 03:36:32 PM »
There's a test of the 19-V and several tests of the BB version at http://sceptreflight.com/Model%20Engine%20Tests/Index.html
Tags: Enya .19-v
