I have a Twister with a GMS .32. Last year the engine had the rc carb on it, couldn't keep it running for more than a minute. Over the winter I decided to put a venturi on it to see if that solved the problem. I found out today it didn't. Here is the setup Gms .32, evo venturi(smallest) Gms remote nva, os spraybar. I'm running a Brodak tank centered on the engine case. It doesn't seem to matter whether its on muffler pressure or not. I'm going to replace the GMS with an Os 40fp, because its my only plane set up for a stooge, but I'd like to get this setup to work. I have considered replacing the Gms rnva with a Brodak nva. It will run in a hard 2 cycle, then I back the needle off, to about 75%(rpm), by the time you get to the handle the RPMs are down, half way back to the plane it's stopped.
Does this sound like an air leak? Thought I ask for advice before I tear into this.
Ps I'm running Byron 10% (20% oil i think)
